**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
Contact Barn of parts advertiser here for push pins
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
I just installed rivnuts on both lower panels and for the beltguard. Really opens things up and makes everything so much easier. I bought a rivnut kit on amazon for $32.90 and it worked great once I figured out how to use it. I used M5 aluminum rivnuts throughout.
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
It really does make life so much easier when servicing these sleds....
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Hey I have thinking of doing this also!!I just installed rivnuts on both lower panels and for the beltguard. Really opens things up and makes everything so much easier. I bought a rivnut kit on amazon for $32.90 and it worked great once I figured out how to use it. I used M5 aluminum rivnuts throughout.
What length ar they? 13mm?
And how many are required?
Marc
DMCTurbo
- Nov 12, 2005
You need 9 each side. I'm not sure what the length is but I used 5mm rivnuts for it all. It's quite easy to do. The hardest thing was figuring out the rivnut gun lol but that only took a couple minutes.Hey I have thinking of doing this also!!
Marc
I used 6mm Rivnuts from Mcmaster-Carr . you will need the longer rivnuts where you are going through more material
Zinc-Plated Steel Heavy-Duty Rivet Nut
Open End, M6x1.0 Interior Thread, 4.2-6.6 mm Material Thickness
95105A187
Open End, M6x1.0 Interior Thread, .7-4.2mm Material Thickness
95105A183
Alloy Steel Flanged Button Head Screws
Black-Oxide, M6 x 1.00 mm Thread, 25mm Long
92137A540
95105A187
95105A183
92137A540
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
ThanksI used 6mm Rivnuts from Mcmaster-Carr . you will need the longer rivnuts where you are going through more material
95105A187
95105A183
92137A540
Phatboyc
- Apr 2, 2007
- Ottawa, Ontario
- 2022 Sidewinder
How did your Polaris RZR style push pins worked last seasons? I was considering this or M5 rubber well nuts.
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
I would personally stick with the metal zinc rivnuts, the rubber style ones may not last long when used for this application.How did your Polaris RZR style push pins worked last seasons? I was considering this or M5 rubber well nuts.
