RX Turbo build-up (with pics)
lakercr
Tech Advisor
Winnipeg, Manitoba
Canada
2025 SRX
Things have bee a bit skinny around here lately with build pictures, so I thought I'd thow some up (I know I like to look at what other guys are up to). This is a customer's sled (Rx1 Fern) that came in to us earlier last week.
I didn't take any pics of the initial teardown (seat, tank etc.) so I'll start with checking the valves and pulling the head. This motor was running ECP's with 170 mains at 700' elevation. Just a little 'chubby' on the jetting...
Head back on with shim, cam timing set.
Oil adapter installed.
Head back on with header installed.
Track out for extroverts. Windows had to be cut.
On to the carbs. Billet 'T''s installed, stock screws swapped out for Allen head bolts.
Installing the gauges into the BPE pod
Modifying the 'S' pipe. Powderlites has improved this piece significantly since the kit pictured was first on the market. We had to fabricate a 'Y' pipe - customer wanted to run his aftermarket exhaust.
Closing up the rear hole in the tunnel, exhaust back in.
BPE louvered inspection plate installed.
Starting to put parts back on...
Rear end buttoned up...
Finishing up under the hood.
Down to the short strokes, BPE hood scoop installed.
