pierrevtx1800
- Feb 18, 2016
- Québec
- Yamaha Sr Viper 2015
i am from Québec and i had very bad starting and backfire my Sr Viper got only 7500 km and the dealer told me my valves was too tight
so they do a valve adjustement and changing shims and they told me Yamaha is paying for shims and 3.5 hours so i have to pay the balance 3.5 hours
because the total job was 7 hours ma warranty was over. Cost to me $ 337.35
Mike P
- Nov 18, 2015
- Berlin CT
- Sr Viper R-TX SE
- Berlin CT
Did it fix your issues?i am from Québec and i had very bad starting and backfire my Sr Viper got only 7500 km and the dealer told me my valves was too tight
i know on my xt350 when the valves got tight, it ran nuts hard until they would not close enough to start it any more.
Allan
- Oct 19, 2014
- Newfoundland
- 2016 Sr Viper XTX
Yesterday when riding in powder and on the throttle and I let go of the throttle and let the sled come to a stop it stalled. )This happen to be several times. (Check the tbs and it was 0 and 100%Mine does same thing Allan. Hopefully all these weird run quality issues are just the programming/flash and not a internal engine issue like tight leaking valves. Will soon find out. I have one more ride planned for next weekend then will dig in.
The drop to Low idle (1250 rpm) on start up, now stalling . makes me wounder what going on. Rolled up on 18, 000 km today (3 winters ). All this only started in the last few weeks.
Mine is a 2016 and they changed the camshaft , valves stems and springs in 2016.
SounderMN
- Sep 26, 2011
- Minneapolis, MN
- 2015 Yamaha Viper LTX DX
Allan
- Oct 19, 2014
- Newfoundland
- 2016 Sr Viper XTX
Changed them at the start of this season . 5400km on them.
Harvest1121
- Dec 15, 2010
Mine have been changed every season started fine cold just when it sat for a few minutes
savageman69
- Apr 21, 2014
- 2014 arctic cat zr 7000 limited
ive changed my plugs 2 times since new...have almost 9000 miles and mine has never not started...and if i wait for the fuel pump it fires great all the time.
I think we should do a poll to see how many people are above 10k miles and if anyone else have had valve failures...be nice to track down the route cause....stock exhaust maybe? muffler? driving style...something to get us better info
fasteddie15x
- Jan 20, 2014
Crap! Looks like I am checking valves this spring. I am hoping for good news since mine has gotten faster every year. But it has always had crappy idle but always was a good starter. The two start trys and even lately stalling on warm up after light is out I attributed to the tune and having stock exhaust back on but now I am worried. Could this be the reason behind variances in engines and terrible starters? Heck even could account for a kickback! Not happy this happened to even 1 person. No warranty either. XXXX!
http://www.arcticchat.com/forum/pro.../477809-7000-4-stroke-after-25-000-miles.html
Hmmm I seem to have the stalling on warm up issue also, to go with my overheating issue. I wonder if tight valves are my stalling issue?
I haven't had a chance to look any further into the problems. I guess it will be a summer project. I have 1200miles on mine
RTX
- Mar 31, 2005
- massachusetts / maine
- 2014 viper rtx
2006 apex rtx
Mine has always idled weird at start up, but this past weekend my second stock muffler blew a hole in it.
Now on cold starts it will not even run. It starts, burbles for a second then stalls. I have to give it gas to keep it running and it sounds like its running on 1 cylinder till it warms up then it is fine.
Just out of curiosity i think you should check it for minor exhaust leaks
4strokes
- Mar 13, 2018
- charlemont ma
- 18 winder xtx 09 nytro xtx 06 apex gt
way back when yellowknife was considering burning his viper. I thought burned ex valves, I figure with the front exhaust the valves are probably hotter. my nytro is nearing 24000 miles and it is getting to where when warm I have to crack the throttle a hair for a quicker start. I plan to shim this summer. hope the engine can stay in place.
Barry
- Mar 11, 2015
- bridgewater
- SR Viper
My 2014 XTX just starting doing exactly what you mentioned. Good one day. bad next five days. Most problems at cold start up. Never had them last week, dealer says valve adjustment. Just not convinced yet? Any solution????
SqueezeER
- Jan 16, 2019
- Northern Ontario
- 2020 Winder Ltx LE
After 5 years and 25,000 miles I just replaced my Arctic Cat version of the Viper. I did less maintenance than is recommended on these pages. I relied on inspection and a maintenance schedule that resulted in very little interruption to the short snowmobile season. Disregarding wear items I had little breakdown before 15,000 miles. After 15,000 miles the parts that one would expect to fail didn’t and parts that should not fail did. Some of the unique repair requirements have been documented on the Arctic Chat forum. Parts that did not fail include the track, skid frame wheels and the clutch. The original belt lasted 15,000 miles. Parts that did fail included the valves, chain case and all related parts plus some others. Any thoughts or questions?
15000 miles on a belt?? wow nice!
SqueezeER
- Jan 16, 2019
- Northern Ontario
You guys make it sound so easy. Ya just rebuild the motor, then put it back to together.....take off every bolt, inspect every piece, and put back together....is everybody a mechanic in this place? HA. I wouldn't even know how to change a wheel. I took the belt off yesterday, and it took me 10 mins to get back in...trying to open the clutch by hand, no adjuster tool! Frayed my belt a bit in the process
Some guys have some serious miles in this forum, which I'm sure is because you guys all know how to well maintain your sled! Knowledge is very valuable. For me, I'm gonna run it until it breaks, then bring it to the dealer and get them to fix it. I won't have this sled when the warranty runs out, so I'm gonna drive it like I rented it! But hey, I am a millennial after all!
