KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
With the 8jp I'm getting what I think is track ratchet up to about 40 mph & vibrations at over 105 mph . I will have to try out a 8DN see if that goes away
The heavier secondary spring is what gave me better grip in the driven sheaves in the top end where I was having issues. I opted for the 8DN as harder belts do better with the added grip of the heavier secondary spring. An added benefit is better backshift and response also.
Just switching to the 8DN won't do much for you without added side pressure in the secondary.
race24x
- Dec 29, 2003
- Belgrade, Maine
- www.r-scomputer.com
Knapp, I am glad you brought that ratchet thing up. I was having this too. I complained to my dealer as I thought it might be chaincase or something. I had never see extroverts ratchet if the track was even close. I made my track very tight and it was still there. I suspected the clutches but hadnt seen anyone else complain of this. My clutch kit seems to have fixed the issue. I bet it is better for belt life too...
Mototown
- Sep 11, 2018
- Apex 40 th
I like running the track on the lose side but kept tightening the track a turn , what normally fixed about 5-6 skips on take off on the old Yamaha's . But never really got better. Just ordered a tan secondary spring from dalton will give that a try this weekend.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Please keep us posted on that spring. ThanksI like running the track on the lose side but kept tightening the track a turn , what normally fixed about 5-6 skips on take off on the old Yamaha's . But never really got better. Just ordered a tan secondary spring from dalton will give that a try this weekend.
- Nov 29, 2009
- sabattus, maine
My ratcheting feeling isn't on takeoff. Mine happens when you're cruising 50mph or so and mash the throttle a few seconds later when the boost hits I get the nasty ratchet sound/feel. Anybody else having this. I kept tightening up the track little by little last season trying to get it to go away.I like running the track on the lose side but kept tightening the track a turn , what normally fixed about 5-6 skips on take off on the old Yamaha's . But never really got better. Just ordered a tan secondary spring from dalton will give that a try this weekend.
KnappAttack
- Feb 19, 2004
- Welch MN
I was getting what I thought was ratchet and bad vibration up around 90-100. Ran the track fiddle string tight and still did it. I even thought my stud pattern was crap and vibrated.
This season, same track on the machine, my track is a bit looser and I feel the heavier side pressure from the EPI purple spring got rid of the slippage and vibration I was getting in my driven clutch. All is smooth now and machine trucks upstairs and keeps right on pulling with the heavier driven spring. No vibrations and no track ratchet sensations or feelings. How much is heavier spring and how much is better offset from Hurricane alignment bar? I don't know for certain, I do know I'm much happier with the performance this season with all of it working properly.
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
2017 Sidewinder LTX LE
I'll be able to tell you in 2 weeks. I had the same vibration you are describing. Only thing I have changed is aligning the clutches and eliminating float. I turned the HP up as well so if that vibration goes away then I'm on the right track.I was getting what I thought was ratchet and bad vibration up around 90-100. Ran the track fiddle string tight and still did it. I even thought my stud pattern was crap and vibrated.
PowderFalcon
Pinnin' it!
- Jan 29, 2007
- Drumbo, ON
- 2021 Sidewinder SRX
400 miles on my SRX. 1 first belt blown after using alignment tool and removing 2.9mm.
Doowithblue
- Mar 17, 2016
- Waterloo ON
- 07 Mach z x (sold)
18- RTX LE
What speed brent? 8jp?
PowderFalcon
Pinnin' it!
- Jan 29, 2007
- Drumbo, ON
Had just done a straight away at 120mph. Then cruising at 80mph and it exploded.
824
Doowithblue
- Mar 17, 2016
- Waterloo ON
18- RTX LE
Brent why the 824 if i may ask? 1 13/32 width x 44 1/4 long vs 1 7/16 wide x 44 3/8 long for 825.
- Nov 29, 2009
- sabattus, maine
Everything else stock?400 miles on my SRX. 1 first belt blown after using alignment tool and removing 2.9mm.
Mototown
- Sep 11, 2018
- Apex 40 th
PowderFalcon
Pinnin' it!
- Jan 29, 2007
- Drumbo, ON
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
No he is boosted.Everything else stock?
- 9K
