Crewchief47
- Jan 16, 2006
- McGregor, ON Canada
- 2008 Nytro MTX 45th
tubing will be stronger than bar stock. You could look around the net for some chromoly or Ti.....Should be someone out there making custom length sleeves, particularily the circle track or kart industries(transmission shifter rods would be close tothe same dia).
Nikolai
Thanks, come to think of it there is a guy on Snowest that makes stronger tie rods.
summitking
Pm wildchild on snowest he can hook you up
SideMountAK
HYFLYR said:summitking said:HYFLYR what are you riding?
Thats a tough one to answer, do you want to know which one i ride or the one i own, because its a different answer, lol. Either way im on a apex and lovin it.
I think its safe to say he has been "tuning a turbo all winter".... Mine as a matter of fact
and doing a very good job of it. too.
My sled likes HYFLYR better than me this winter
Nikolai
Finally had to do something about the side panel vents. Every time I'd roll the sled the vents would loose a clip and partially fall out resulting in 10 minutes of hassle in putting one back on or having snow in the clutches. I cut and bent 3 small tabs out of sheetmetal and riveted one side to the plastic and the other side just backs the vent. I also put 2 rivets through the vents themselves. Now I can roll it over and over and not have to deal with the vents popping out.
I also got a complete(4 a-arms and 2 spindles) spare front end for a killer price as a backup set, and to work on making the lower ball joints. Now I don't have to tear mine apart to do ball joint/spindle work.
Nikolai
Almost had to be towed out today. My oil tank started leaking around the seam at the bottom like the tank is going to split apart. Emptied what oil I had left, JBwelded the crack and put the oil back in. I lost about a quart and a half but had an extra quart with me I always carry so I was able to start with 2.5 quarts. When I got back to the truck(10 miles later) I had 1.5 quarts left(drained it again so it wouldn't get on the trailer). I'm going to get a new tank under warranty but I think I'm going have the seems welded and run the tank I have now. I don't want to have to deal with this again.
Nikolai
Pics from today...more proof that Yamis are too heavy to jump
HYFLYR
This had nothing to do with it im sure, lol......
HYFLYR
HAHA, you stole my pics buddy! Your in them but there mine, lol.
gormleyflyer2002
dude, i love love looking at your pics......awesome.
Nikolai
rfabro
Cool. I was about to demand more pictures from you guys! Thanx!
Nikolai, that's about a hundred feet, eh? That jump is perfect for working your way up and going further and further down the landing. Did you have all the speed you could get on that one, or is there enough run-up room to go further?
HYFLYR
pretty sure he was tapped out! it had a killer uphill run to the jump that ate alot of speed
Wow!
Nikolai
Got 1,750 miles on the sled and last weekend while going uphill doing 40 mph I stabbed my track and tore it in half. Had to tow it out of the mountains backwards.
Time to start tearing it down I guess. Oh well, rebuilding is the funnest part of sledding.
