I've been playing around with the Hurricane alignment tool today and noticed that my secondary bushing seems to have a fair bit of slop in it for a sled with only 1400 miles on it. Anyone else notice this? A worn bushing is pretty hard on belts.
Trussman
JAFO
- Mar 18, 2007
- WI
- 2004 Viper S
2017 'Winder
2022 SRX
I thought mine had a bit of slop when brand new.....
fourload
Mine seemed sloppy when new also.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Yes alot of play from get-go here too.
Are you able to get down to around 59mm or so?
Yup, around 58.5 now with a 1mm shim in the back. Had to take off ~3mm from shaft to get there.
Soupy
- Jan 10, 2017
- West Michigan
- 2017 Sidewinder LTX-LE
So what offset (measured the normal way) does the tool suggest should be used? When you set it up hurricanes way, what does the offset measure?
My offset is about 58.5mm. I couldn’t get anywhere close to this without removing some material from the secondary. After cutting it, my offset is pretty much bang on where Dave wants it using the tool.
Soupy
- Jan 10, 2017
- West Michigan
My measurements:
Shaft 1.500
Secondary moveable 1.510
Stock helix 1.505
Aftermarket helix 1.501
I have a new bushing for the secondary but haven't replaced it yet. When the secondary is assembled and cycled without a spring the bushing slop seems less problematic.
I took a quick look through the service manual for a spec but didn’t find anything yet so haven’t measured mine. Don’t know that this is a problem or not.
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
Didn' Dave say that his tool needs an update That it was manufactured wrong ?My offset is about 58.5mm. I couldn’t get anywhere close to this without removing some material from the secondary. After cutting it, my offset is pretty much bang on where Dave wants it using the tool.
Yes, but Dave sent me a text with correct thickness and I modified mine.
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
K. So around 58 -59 mm .
Yes.
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
Does the tool check anything other than offset ?
No, it just measures offset.
ETA - it doesn’t require any measuring. It is a go/ no go type of jig.
