thunderbolt
I noticed while running on my lift the secondary does not consistently return fully . sometimes the belt rests at the top properly and some times it sits about 3/16 down in the sheave , what am i missing ?
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Might depend on how much brake you are using to stop the track.
thunderbolt
Didnt touch the brake , let it stop on its own, but good point
thunderbolt
should also mention . I did install the OPS belt adjusting assembly
sledding rocks
- Feb 11, 2017
- north
- sidewinder
yes this is common ,
thunderbolt
really , how come ?
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
To much friction in the drive train and track compared to a Japanese built Yamaha.
sledding rocks
- Feb 11, 2017
- north
- sidewinder
I'm seeing the same . I'm thinking the spring tension needs to be increased if u want to see the belt come to the top . this will make the secondary clutch backshift faster which should bring the belt to the top easier . but I'm not sure how it will perform with the increased spring tension as i have not tried this yet .
i just installed the 33/35 helix with the dalton blk/orange spring . 6-1 hole setting , no difference the belt stills struggles to come to the top . if u play with the throttle u can make it shift and come to the top , but if u hit the throttle hard and release quickly , the belt won't shift to the top of the secondary , this is what I'm seeing on a jack stand also . once there is snow to test better I'm sure this issue will be resolved quickly .
XP123
- Dec 25, 2016
- Chautauqua NY
- Sidewinder XTX LE 137
This is normal. There is no load on the secondary and it won't always fully close. Check it when you ride it and make sure you coast to a stop and not hit the brake. I remember racing guys who would use their brake just before the starting line and I knew I had them because they would be starting in high gear.
yamagone
- Dec 17, 2008
- Essex, Ont. Canada.
- 18' Sidewinder
LOL 10-4 on that. I used to love it when guys beside me would clean their out on the stand and jam on the brake before planting it.This is normal. There is no load on the secondary and it won't always fully close. Check it when you ride it and make sure you coast to a stop and not hit the brake. I remember racing guys who would use their brake just before the starting line and I knew I had them because they would be starting in high gear.
- 24K
