ronzx9
- Jan 11, 2017
- Ohio
- 2017 Sidewinder L-TX-LE, 2016 Grand Touring SE 1200
Guys,
I was checking my offset with the Hurricane tool and noticed something that doesn't look right. Are there supposed to washers between the helix and the secondary on the studs? It doesn't look like they should be there but the previous owner may have put them in. Any Idea why someone might do that?
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
This was an early mod on 17s to help with coil bind when using stock spring.
With Dalton spring, not needed.
Dan
Dan
ronzx9
- Jan 11, 2017
- Ohio
OK When I tighten up the helix without them it's putting a lot of pressure on the rollers. Is that normal
Hammer70
GRIPNRIP
- Sep 6, 2015
- Niagara, Ontario.
Yes that’s normalOK When I tighten up the helix without them it's putting a lot of pressure on the rollers. Is that normal
ronzx9
- Jan 11, 2017
- Ohio
Thanks guys
Hammer70
GRIPNRIP
- Sep 6, 2015
- Niagara, Ontario.
Brian Friebel
- Jan 3, 2016
- Neenah Wi
- 2015 Yamaha Apex
Took my secondary off to clean it up and to change my Helix back to a straight 35 verses the 33/35. I did not notice this when I changed the stock secondary spring to the Dalton Black/ Orange. Updated version so was set at 6-2. Anybody come across this on there secondary clutch? I never blew a belt yet with this sled. Is that going to be a problem do i need a new secondary?
Chris Rose
- Jul 29, 2016
- Powassan ONT
- 2017 sidewinder stx-DX with TD/Max 16 stock muffler
- chrisjrose2018@@gmail.com
I noticed the same
I noticed the same on my helix while I was servicing the clutch. Called Dalton and was told that it's a normal thing and not to worry.Took my secondary off to clean it up and to change my Helix back to a straight 35 verses the 33/35. I did not notice this when I changed the stock secondary spring to the Dalton Black/ Orange. Updated version so was set at 6-2. Anybody come across this on there secondary clutch? I never blew a belt yet with this sled. Is that going to be a problem do i need a new secondary?View attachment 149584
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
Normal rubbing, no worries.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Yes ha must of been aware of spring bind with stock set up,and was trying to lessen that effect.Guys,
- 12K
