ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Im pretty sure the mounting is all same as Viper....which is all solid if I recall. TCL was only the SUK deal i think.In the clutch bay area where you see both clutches it appears as though it has some sort of TCL behind the clutches,is this an old pic or does it have the motor hooked solid? Also the primary ramp looks like it may run some heavy rivets,unless them three holes are deceiving to look at?
dan
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
Can we stil used the old or " std" cam helix?
Wich spring and cam they were using for testing at snowshoot ?
Ding
- Dec 21, 2004
- Howell, MI
- Black & Blue
The charts show which parts are "New" meaning they are likely not interchangeable. The helix is listed as "New". I would be surprised if you could use the stock helix with rollers.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
NO
- Apr 14, 2003
- Hessel, Michigan
OMG!!!!!
Thank you Yamaha for coming up with flat pucks riding on machined surfaces in the primary!!!!!
I believe all the primary clutching issues will be eliminated!!!! I just wet myself!!!!! Woo Hoo!!!!!
Here are a few more pics of the SideWinder clutch all ripped apart:
- Apr 14, 2003
- Hessel, Michigan
I really gotta give it to Yamaha for the changes to the primary!
Be nice to have shims that will go under the pucks when wear becomes a factor
Doowithblue
- Mar 17, 2016
- Waterloo ON
- 07 Mach z x (sold)
18- RTX LE
Like one member asked on pg 1 anyone know how to adjust belt deflection?
I would think it would be the same as any other Yamaha Secondary. Using washers on the back of the 3 bolts on the secondary.
super_rash
- Feb 24, 2014
i too red somewhere belt deflection adjustment was easier can't remeber where.. is this not a pre production model? and how close do you think the production models will be? thanks for info..
I just love those roller secondaries...
Doowithblue
- Mar 17, 2016
- Waterloo ON
18- RTX LE
Like a friend of mine said the belt deflection adjustment is very primative. Pretty sad for a sled that costs this much.
All these complaints on price and what it should and shouldn't have.. its easy and I hate to say this but then dont buy it.
Snake
- Mar 3, 2016
- Maine
- 2017 Sidewinder XTX 137 LE
Would you prefer something more wizbang, with a commensurate increase in price?Like a friend of mine said the belt deflection adjustment is very primative. Pretty sad for a sled that costs this much.
Doowithblue
- Mar 17, 2016
- Waterloo ON
18- RTX LE
Yes.
Snake
- Mar 3, 2016
- Maine
To be honest, when I first heard about, and saw the sled, I thought the price was close to reasonable. I mean, what exactly do you expect with a sled that has the tech this one does? Not to mention the fact it seems you can't swing a dead cat without hitting a dealer who will knock $1,000-$1,500 off without batting an eye.All these complaints on price and what it should and shouldn't have.. its easy and I hate to say this but then dont buy it.
