i too red somewhere belt deflection adjustment was easier can't remeber where.. is this not a pre production model? and how close do you think the production models will be? thanks for info..
I just love those roller secondaries...
Ill try to get some pics of the adjustment.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
what I dont like or understand...the yamaha primary has always been rock solid...and the slider bushings were top notch...why the hell would they go to buttons (ala poo and doo) which will fail way quicker? what for a littler less drag=power?
god I hope these come with all replaceable bushings like the old clutches and not the pressed in #*$&@...
super_rash
- Feb 24, 2014
me too am wondering why the change in the primary...but i'm sure there is a good reason that will still maintain reliability
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Well I can tell you from personal exsperiance with Yamaha clutching,and I have run all of todays sleds clutches,sense I have owned several from all 4 manufacturers,yamahas are the easiet to tune,and the best to stay tuned,you do the least on either primary or secondary,so don't worrie aboput taken three little bolts out and adding or subtracting a washer to adjust deflection,because these clutches are so good to belt life you wont be adjusting much at all,unless you run aftermarket weights and helix's that require some test and tune,if you keep it all stock,you will go all year and than some on stock belt.Like a friend of mine said the belt deflection adjustment is very primative. Pretty sad for a sled that costs this much.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Well there change required a larger dia. primary,so I guess there must of been some input from some about the plastic square pucks that I like to the old style poo style round pucks,while they were making a larger primary,i am sure with Yamahas quality we wont have a problem,i have had lots of poo's over the years,andd nnever had one failure with there primary clutch.me too am wondering why the change in the primary...but i'm sure there is a good reason that will still maintain reliability
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
Deflection is a mean nothing adjustment anyways...is the least important
- Apr 14, 2003
- Hessel, Michigan
Guys, I know the stock Yamaha primary was good, but the spider plastic bushings slid on cast surfaces. I believe that right around 2013 is when some casting molds had to be updated/re-made and since I work on clutching....you wouldn't believe the issues I have come across. I believe a lot has to do with why the Viper clutching needed so much attention....especially in the casting flash areas and drag on the primary.
I am so glad that we now have a fully machined clutch where the flat pucks ride on machined dimensions....not cast. Not to mention that as the new clutch wears, the flat pucks can be replaced and shims added under the pucks for precise tolerance. Look in your clutches and see how different the spider pucks are making marks in your moveable sheave.....you will think different after seeing it for yourself.
This new clutch with larger diameters will be just as strong and move freely as a billet aftermarket clutch. Add a 911 cover from Thunder Products and you will also have the strength of an aftermarket clutch. I'm very excited to see this clutch work.
Here is what I have for the secondary.
Note the 3 screws on the back side of the secondary are not longer used. Washers behind the secondary on the jackshaft are for setting proper off set.
They now add washers to the front side in different thicknesses to set the belt deflection.
Doowithblue
- Mar 17, 2016
- Waterloo ON
- 07 Mach z x (sold)
18- RTX LE
View attachment 117792 Will the osp adjuster work on the new secondary?
Thats a great question. I will have to see.
Doowithblue
- Mar 17, 2016
- Waterloo ON
18- RTX LE
Btw sweet pics Mr sled!!!
AXR
- May 5, 2007
- Central NY
- Current: 2017 SideWinder L-TX LE
Past: 2015 Sr Viper R-TX SE, 2008 Apex RTX, 2002 Sx Viper, 1997 XTC 600, 1991 Doo Formula Plus.
That's probably what gave Yamaha the idea to add washers to the outside
Look how far down the belt was on that middle top picture. Impressive. That clutch was hauling!
- Apr 14, 2003
- Hessel, Michigan
I believe it will work, from what I am seeing in the pics. I will be bringing some stuff with me April 10th....if they let me do some wrenching
Be good to see and have answers to my clutching questions.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
thanks for explaining....makes sense...I havent fooled with the clutches since my 12' and barely then either...
I would have to agree then if there were binding issues...
