Sidewinder just Shutoff on trail
michigan
Rode about 100 miles and just cruising along and the engine just shut off. It was running fine before that. Engine turns over fine. I can hear the fuel pump. Any ideas.
Kill switch/tether?? I know obvious but just asking. Any codes on the dash?
Check battery cables.. Sounds electrical
By passed tether. Engine turns over fine there are no codes on the dash. Was told to check the crank sensor. checked everything
Try disconnecting the battery for a few minutes and then reconnect. Kind of a ECU reset.
I tried disconnecting and reconnecting it still won't start. I will have to wait till I get back home to get into more. Thanks every body for the suggestions.
Check for rubbed through wires up by fuse block! Sounds like one might have rubbed through and grounded.
