I will back you on that one. Same thing here. If the owners don't report it and bring it in Yamaha does not know. Happens way more than a guy would think. Dealers also will not acknowledge a issue unless they see it so bring it to their attention. Everything. I still am only one to warranty a worn top gear bushing,driveshaft wore from spun bearing and grooved brake Caliper and I know for sure there are many out there. Not going to get fixed for good with only one guy reporting it.The dealers I have spoke to are close friends of mine and dont lie to me..LOL
yamaha06
I sanded entire ramp surface starting with 120 grit and finished with 320 followed by 400. It did not take much on mine to make 3rd roller contact. I have put on 1,000 miles sine I did this and it looks fine. I'm going to buy rollers from Ulmer when I get back from my trip.
Thanks! Did you check the roller contact with the spring removed? I only had one roller touching. I had to sand the one ramp a lot! And the second one slightly. When I would check contact of the rollers I would put helix on without spring, third one would touch somewhat but not like the other two. Installed everything and checked again and all 3 rollers are contacting ramps.
johnnysnowking
I have had a bunch of issues but it's luck of the draw. My dealer told me I'm the only one that he sold that's having issues and Yamaha said they have had very little issues at all. ????
Many just are not as informed or just not noticing. I just helped a guy setup his suspension on Winder and glanced at his clutch. Sure enough flat roller. Did not go over well with the owner when I pointed that out so I stopped looking at his sled. But he never knew.I have had a bunch of issues but it's luck of the draw. My dealer told me I'm the only one that he sold that's having issues and Yamaha said they have had very little issues at all. ????
Pierre Castonguay
- Aug 25, 2016
- Saguenay, Quebec
- Viper, Apex, Sidewinder
As for roller spot and broken belt go with a 41/37 helix at 3/3, will reduce belt tension and heat! The stock 35 helix on the secondary clutch is not the proper helix! With that set up never broke a belt, and trust me I ride my sled extremely hard!
Pierre Castonguay
- Aug 25, 2016
- Saguenay, Quebec
If you don't believe me, I got all my Infos from Gille at GForce in Coaticook Quebec I know the him, he has the world record for sled top speed (210 mph).
Sidewinder Slayer
- Dec 30, 2014
- 2007 apex rtx
2007 phazer
2017 sidewinder ltx le
I've got 300 miles now the only issue (chime in if u have had this or can help me) is if I pin it right to the bar (which is often ) I get 3 seconds of accelerating, then it cuts out. If I keep holding down to the bar it cuts back in and then again cuts out.
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
I believe you are running a turboforce exhaust and will require a flash...I've got 300 miles now the only issue (chime in if u have had this or can help me) is if I pin it right to the bar (which is often ) I get 3 seconds of accelerating, then it cuts out. If I keep holding down to the bar it cuts back in and then again cuts out.
DIwarrior
- Oct 22, 2003
- Drummond Island MI
- 2025 SRX LE #473
2025 SW XTX LE
2025 SW LTX GT
2001 SRX
1968 Ski-Doo
- Drummond Island, MI
- Nope
How many miles on a stock sled & belt are we seeing? I've got a 1,000 miles on my stock LTX-LE so far. Most of the guys blowing belts seem to be on sleds that they have made either Clutching or HP changes.
craigwsrx
- Feb 19, 2007
- Fenton Mi.
- 2017 Sidewinder 27,000 miles
2009 Nytro xtx 31,000 miles
2006 Attak 26,500 miles
2003 RX1 13,500 miles
2000 Mountain Max 14,000 miles
1998 SRX Mountain 17,000 miles
1995 V Max 600
1979 SRX 440
1975 GPX 338
1973 GP 338
I just returned from my trip to the Gaspe Quebec and have 2,900 miles at this time. I did change my original belt at 700 miles due to flat spotting it getting stuck on a dead end trail. So I have 2,200 miles on current belt. I have to admit I only pinched it off a couple of times on the wide open trails of Quebec and did break trail in 2 feet of fresh for 60 miles one day, with the clutches staying cool for conditions. Clutch sheeves look great with no black from belt. Also I am happy with fuel mileage, able to get 125 miles on a tank when needed. Haven't tightened chain yet, thinking of paying dealer for this and letting him deal with muffler bolts. All in all I am very happy with this sled and enjoy it, awesome sled.
Pstn head
3200km on a belt with lots of high speed running
Sidewinder146
- Jan 10, 2017
- Newfoundland
- 2017 Yamaha sidewinder
I had the same problem, sled was freezing up due to water in the gas. I put gas line antifreeze in it and problem solved !
Kevin
- Dec 20, 2006
- Ottawa Canada
- Sidewinder
Take your seat off once and a while and check your battery
Looks like mine had been leaking, the acid ate the stitching out of both sides of the seat
Battery must be cracked somewhere
I will have a new seat cover and new battery within a day
All warranty of course
Dieselxtx
- Feb 21, 2016
- Fox Lake, WI
- 2017 Sidewinder BTX LE
2012 Nytro XTX 1.75
I have a sway bar bushing gone on left side and now swaybar is rubbing my panel and my left shock doesn't hold pressure in the evol chamber it leaks out its going in for warranty this week
bleedyamaha
- Sep 28, 2013
- Northern Iowa
Yamaha replaced my secondary rollers with different ones. Fixed my thumb warmer " broken wire" replaced heat shield. Did something with my muffler bolts and retorqued my turbo bolts. Also adjusted my chain case. All warranty and recall
- 8K
