- Apr 14, 2003
- Hessel, Michigan
For anyone who is looking for a better secondary for their Viper....the Sidewinder roller secondary fits and I think will be a good upgrade once aftermarket helix's are made (which I heard from one company that castings are already being made)
Thunder Products also has Encapsulated Roller setups for your Viper stock secondary He has helix's in stock right now.
This with a belt adjuster...and you would be all set!
Mitch Desorcy
MAX PRO
- May 6, 2014
- Winnipeg Manitoba
- 2014 Yamaha SR Viper LTX SE
I looked at the Thunder website and didn't see an encapsulated roller kit for the Yamaha clutch. I know they used to have one.
- Apr 14, 2003
- Hessel, Michigan
They have 25 Encapsulated Roller setups right now....just talked to Lonn 20 minutes ago.
putz21
- Apr 15, 2013
- Tomahawk, WI
- '23 Sidewinder LTX LE w/EPS
‘19 Sidewinder LTX SE
Have you tested this setup with your Viper yet? If so, your thoughts and impressions?
- Apr 14, 2003
- Hessel, Michigan
I've had the encapsulated roller setup on my 2 stroke SXR 700 and it was awesome!
I can only imagine it will be so much better than the stock button secondary.
I will have Lonn send me some pictures and he is sending some items my way anyway....I'll try one out.
putz21
- Apr 15, 2013
- Tomahawk, WI
Sweet! Can't wait to hear about it!
- Apr 14, 2003
- Hessel, Michigan
Here is a pic I found on the internet.... this uses your stock sheaves.
Pretty neat setup and I loved how adjustable they are. You have a bunch of spring setting holes and then you can loosen the 3 12mm nuts and rotate any pressure on the spring you want. Very quick and very easy.
putz21
- Apr 15, 2013
- Tomahawk, WI
Here is a pic I found on the internet.... this uses your stock sheaves. View attachment 121999
Nice find! Looks to be very adjustable indeed. Might be a great option to try and play with. Any idea on the cost of this or PM me if you know.
- Apr 14, 2003
- Hessel, Michigan
Thunder Products is selling the Encapsulated Roller setup for $395 and that will include the helix...any angle you want.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
I will likely be selling the roller secondary from my sidewinder once I get it.
Dirtbikekid1998
- Mar 3, 2013
- Maine
- 2014 Yamaha Viper LTX SE Hurricane 190hp Turbo.
Wanted to bring this back up to see if anyone has tried this? Would it even be worth it over the viper secondary?
- Apr 14, 2003
- Hessel, Michigan
The sidewinder roller secondary works on the Viper. I have tried the Sidewinder roller and have the Thunder Products encapsulated roller on the Viper right now
Dinner
Would you say the Sidewinder Roller Secondary out performs the Viper Button Secondary? Or does the Thunder Roller pan out the same?
Cheers
Is a few Sidewinder guys that switched to Viper/Nytro secondary. If interested maybe there are some takers. For me on SRX roller secondary conversion (aaen) was mostly noticed for faster back shift. Was also easier to adjust spring wind. Never converted my 4strokes because of engine braking. Didn't want to make it worse with faster back shift and peak power spread is bigger and easier to hit clutching wise. Would be neat to try though.
darv
- Aug 9, 2005
- International Falls,minnesota
- 08 Apex 40th LTX
i have a roller on my apex ltx running dragon fly and 43-37 helex works great.
