ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Way to go....will be great to get some good tuning with a PB80, and some comparos.....
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Some will laugh at my suggestion for skis, but here goes. Cat skis with 6-8 inch slim jims. You can find the skis cheap. And IMO are damn good if set up correctly. Need to be shimmed, suspension set for rider
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
I have these on my Viper and it steers perfectly. No darting and steers easily. I was going to buy the same set up for my SW but fell into the deal for the Simmons first.Some will laugh at my suggestion for skis, but here goes. Cat skis with 6-8 inch slim jims. You can find the skis cheap. And IMO are damn good if set up correctly. Need to be shimmed, suspension set for rider
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Honestly surprised the SH^# out of me when I shimmed them(CAT SKIS) and ran them. I run 200 some studs in the 137 and figured they would push like crazy with 6 inch slim jims . I ride fairly hard, and love them on the winder
ishpeming fan
- Feb 5, 2017
- Bristol WI.
- 2019 ZR RR 8000
save up your money and buy curves with 6" shaper bars and 4" leading edge. no darting, no pushing,and easy steering. this set up rails corners without a doubt
DranttelSS
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
Honestly surprised the SH^# out of me when I shimmed them and ran them. I run 200 some studs in the 137 and figured they would push like crazy with 6 inch slim jims . I ride fairly hard, and love them on the winder
I ran 6" Slim Jims and shimmed the skis on my Viper XTX. That was the best setup I have ever driven. Probably switch my Sidewinder over eventually.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
I ran the exact same set up on my Viper LTX and it is the best set up I tried. Easy steering and no darting at all. That is what I will probably do to my SW also if these Simmons don't work out.
monte1214
- Apr 20, 2005
- Durham Region, ON
- www.portperrysnowmobileclub.com
- 2017 Sidewinder LTX-SE
My buddy (who bled Blue for years) went to the T-Cat last year, and he swears the T-Cat skis are the best.
He's convinced me to try them on my SW this year.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Basic ski design IMO, agressive and will dart like a mofo....Why i hated them. So they need a dual type cat carbide or slimjim at min.....My buddy (who bled Blue for years) went to the T-Cat last year, and he swears the T-Cat skis are the best.
Pilots cured all those issues.
geez150
On my cat skis I was going to run a set of regular duals. Why does everyone talk about the slim Jim's? Are they that much better being close together?
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
I have run the Curves with dullys on this chassis for 2 years now. I can tell you that everyone that has ridden my sled either already switched to the same set up or are switching this year. I hear people talking about heavy steering with this setup but my 65 YO mom struggled with this chassis for a few years. Now that she's running the Curves it's her favorite sled of all time. If it steers heavy with curves, you don't have it set up right.
So what is your set up. Studded, 4 or 6"slimJims, curves with curve rubbers also??
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
2017 Sidewinder LTX LE
144 studs, singles, center only. 6in slim jims and curve rubbers. If you search my posts I have a thread with my full suspension set up as well. I'll probably tweak my settings this year for a little more transfer but overall this was the best handling machine I ever rode.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
I think they work better because they are closer together and bite deeper. They don't seem to push like duallys.On my cat skis I was going to run a set of regular duals. Why does everyone talk about the slim Jim's? Are they that much better being close together?
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
how will you get more transfer ?144 studs, singles, center only. 6in slim jims and curve rubbers. If you search my posts I have a thread with my full suspension set up as well. I'll probably tweak my settings this year for a little more transfer but overall this was the best handling machine I ever rode.
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
Loosen up the limiter straps one hole. Or pull the adjuster blocks out.how will you get more transfer ?
- 11K
