scottt
- Jan 30, 2018
- maine
- 2007 apex gt 2017 sidewinder LTX LE 137"
Once over 100 mph how accurate are theses speedos? Thanks
Big_Phil
- Feb 5, 2014
- Wasaga Beach, Ontario
- Sidewinder RTX LE
Pretty close. With hurricane tubes, my sled actually gps 1 mph higher than gauge.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
I find them to be about 4 mph off. So 105 on dash around 101
mooser17
- Jan 10, 2017
- Muskoka
- Sidewinder ltx le
Both my 17 & 20 were 2Mph off. 17 would do 126 speedo / 124 gps.. and 20 would do 120 speedo /118gps.. both Ltx's
Slow998
- Jan 11, 2021
- Maine
- 2021 Thundercat
- Maine
My Thundercat most recently showed 135 speedo, 131 gps
Out riding and testing today on my 2019 X-TX data log indicated 120 as a max on my speedo and GPS said max speed reached was 114mph....that was approx 1000' run on fairly loose snow trail.
So speedo over indicates by 5 to 6%
Yamifan
- Apr 16, 2019
- Cuba, IL.
- 2022 LTX GT
Last ride my speedo just ticked 119 when I backed out of it on a rail grade. The max speed stored on the gps was 116.
But you have the different pitch drivers....?Out riding and testing today on my 2019 X-TX data log indicated 120 as a max on my speedo and GPS said max speed reached was 114mph....that was approx 1000' run on fairly loose snow trail.
YesBut you have the different pitch drivers....?
My X-TX came with 3" drivers as compared to most SW 2.86"drivers. It appears that the factory never calibrated the speedos for anything other then the 2.86" drivers....hence the greater speedo error on the X-TXs with the 141"tracks.
Yes, I had an 18 xtx and found the same inaccuracy.Yes
