Simplespeed
- Jan 8, 2022
- 1191 Sauk Lane , Saginaw, Mi. 48638
- 2006 Apex , 2017 Sidewinder LTX -LE
Has any model year stood out above the others? It seems this sled has been extremely consistent and not alot of variables from year to year… Talking about motor performance on each model year in both stock form and tuned form.. Comments on engine and power please…..
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Red ones are faster!
STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
my 2022 just doesn't seem to have the juice my 2017 did. Maybe I am used to it or maybe I just have not yet found the right combo that this sled likes yet.
I will continue to try to find the combo that makes my 2022 go like I think it should
Bigblue1
Blue. Must be blue.Red ones are faster!
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
Blue. Must be blue.
There's no difference that I'm aware of except for the clutching specs that were different on 19's and up.
Turboflash
- Mar 18, 2019
- Southern MN
Engine is same all years as far as I know. P/n's for rods, pistons, rings, crank, valves, head, block are same.
sideshowBob
ECUs would be the only possible differences beyond gearing and clutching specs but it seems all ECUs have been reflashed with a tune anyway!
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
All years and models make the same engine power and are capable of the same power tuned including the Cat versions.
Simplespeed
- Jan 8, 2022
Did you ever get a chance to run them side by side or time them with radar, dragy, or timing lights or even another sled you ride with?my 2022 just doesn't seem to have the juice my 2017 did. Maybe I am used to it or maybe I just have not yet found the right combo that this sled likes yet.
Can't imagine there is a "Faster" year for the Winder. I think it may have more to do with the way they are broken in. I personally think there's allot to be said for breaking them in hard. Maybe this is more myth than fact, but I will continue to run them hard from the get go.
Turboflash
- Mar 18, 2019
- Southern MN
Yup. Run it like you stole it!Can't imagine there is a "Faster" year for the Winder. I think it may have more to do with the way they are broken in. I personally think there's allot to be said for breaking them in hard. Maybe this is more myth than fact, but I will continue to run them hard from the get go.
Simplespeed
- Jan 8, 2022
I would tend to agree with you on a harder than normal break in from my experience with many new sleds .. I can also state that motor’s I broke in using the progressive heat soak method also ran very well… In fact I can also state that I have never has a issue either way… The only thing I have noticed is motor’s that were broke in hard right from the start did have a small amount of additional wear in the cross hatch .. The easy broke in motors look of less wear after the breakin period around 10 hours . This did not effect performance in either case as near as I could tell.. Manufacturing tolerances, oil quality, and conditions the motor was run probably had more influence than how hard it was broke in …Can't imagine there is a "Faster" year for the Winder. I think it may have more to do with the way they are broken in. I personally think there's allot to be said for breaking them in hard. Maybe this is more myth than fact, but I will continue to run them hard from the get go.
Confused
- Oct 12, 2008
- Mound, MN
- '21 Sidewinder LTX SE
'24 MXZ 850 Turbo R Comp
'23 MXZ Blizzard 850 ETEC
'24 MXZ Neo+ 600
'88 SnoScoot
My friends '17 is faster than my '21. Really not sure why other than my '21 has always felt really tight compared to his. No parking brake needed on mine when parked on a hill. His will roll down plus another 100 yards lol.
- 29K
- 7K
