**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
The oily vapor coats the inside of the intercooler and eventually lessens it's abilities... Of course you could remove all charge tubes and intercooler and clean...
slowride06er
- Feb 15, 2014
- Ford River MI
- Apex
Pm sent
sledheadgeorge
- Apr 28, 2003
- Which one? I have 6
If its a variable vain turbo it will eventually restrict its performance.So its not hurting anything as far as power being made with it vented as is? So the oil mist on the turbo,what is that hurting?
Fast
- Sep 25, 2018
Pull the charge tube you will be suprised7000 miles on my sled. I always run it at max level and never have oil in the tubes. But I don’t run in deep snow very often.
Fast
- Sep 25, 2018
Mike do we just flush the intercooler with varsol and let dry or degreaserI tested both hooked up and unhooked on same day, same conditions and logged the runs. I saw no RPM change either way. What I do know is with the hose hooked up factory style, is the mist and vapor coats the whole intake for sure.
I prefer to run with the blowby running out under the running board rather than coating the intake. After I ran that test that day, I did take out the intercooler to see how much oil I had in there and there was of course the coating and a bit of oil in the bottom of the cooler and intake tubes were coated.
Powerwise, I doubt you'd see a horse or two either way. I did the ROV elimination mod to get rid of the ROV and prevent the oil tank seal from blowing which is has done a good job of. Not coating the intake has just been a bonus.
In the 1400 or so miles I've done this season, I have used zero oil and it is still right at the top of the line on oil tank with ROV mod dumping vapor under the running board.
s davis
- May 25, 2018
- Wy
- Yamaha sidewinder
so much debate about the rov my sled does end up side down 2 or three times a yr (powder) no freezing problems, so keep it in place?Mike do we just flush the intercooler with varsol and let dry or degreaser
Fast
- Sep 25, 2018
Nice, i pulled my intercooler because i left the roll over valve to, and oil was pouring out of the hoses will see how much when i flush it.the right hose was sliced about 3" up at the intercooler my wire harness was tywrapped on the bottom of the roll over hose and burnt a flat spot in it from the pipe heat shield have to cut it open to see how bad it is,glad im doing everything my self nowso much debate about the rov my sled does end up side down 2 or three times a yr (powder) no freezing problems, so keep it in place?
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- Sacandaga reservoir
Disconnect line blowing the oil in intake track, plug it and get rid of ROV put on hose loop around and down, will work if you roll over, Rockerdans build way. Had it like this for three years now, no problems, no oil in hoses, intercooler etc, just saying and quit worrying.
Fast
- Sep 25, 2018
Ya probably do that mod this summer ,hows everyone seperating the oil resevoir.while its still on the sled or pull the chaincase the and seperating in the benchDisconnect line blowing the oil in intake track, plug it and get rid of ROV put on hose loop around and down, will work if you roll over, Rockerdans build way. Had it like this for three years now, no problems, no oil in hoses, intercooler etc, just saying and quit worrying.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
I split mine on the machine since I just did gear oil a week prior to my oil tank leakingYa probably do that mod this summer ,hows everyone seperating the oil resevoir.while its still on the sled or pull the chaincase the and seperating in the bench
Turboflash
- Mar 18, 2019
- Southern MN
X2!
Firedawg1998
- Oct 17, 2018
- Sudbury, Ontario
- 2019 srx
Hurricane PM bundle
2012 apex xtx
2012 vector gt
I just did my rov delete on my 19 srx which has 7500km on it amd has never left the trail. I decided to pull my Intercooler. When I tipped it over I had close to a good ounce of motor oil. Topped with white cream.
Really gross. Filled with diluted simple.green, shook for 15 seconds.. had to do that 3 more times. The first rinse was ridiculously. My charge tubes were all coated as expected.....
- 9K
