..SNAKEBIT..
ski-doo jerry can what model?
mounting it on a Nytro MTX
860200281 fits XP
860200194 fits gtx?
860200132 fit pre 07 Rev
what is the difference? are the tanks shaped the same? mounts different?
would one fit the Nytro tunnel better than the others?
was looking to go under tunnel exhaust with OFT cover?
maybe remove rear plastic from behind seat?
860200281 fits XP
860200194 fits gtx?
Doo gas caddy
I use the one for the 07 rev, its fits flat on the tunnel while the one for the XP is raised. I've gone to an under-tunnel exhaust so I removed all the junk from under my seat and put a block off plate in its place. I mounted the gas can right up against the seat brackets I fabbed, so its tucked in nicely and not hanging all that weight way out back.
..SNAKEBIT..
thats what I was thinking of doing
did you grind off the lip for the tunnel block off?
I was thinking of buying the OFT block-off so it could be returned to stock if needed
a few pics would be REAL nice
or e-mail them to me Thanks
PS. was curious about the new xp tank maybe fitting over the OFT tunnel block-off, because its made to fit over the ski-doo cooler????
stopdropanroll
- 47K
- 148K
- 32K
