LazyBastard
Actually, a few people have tested my setup with the warrior and report that it works there as well. Keep in mind that with a warrior, the shock is adjustable, so it may be good to increase dampening - possibly even dropping the FRA to mid at the same time to let the shock do the work instead of the spring.
sledheadgeorge
- Apr 28, 2003
- Which one? I have 6
It will be different. On the Warrior you can use the clicker to adjust the load on the shock. You don't have to let the spring do all the work.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
One thing to remember when adjusting rear shock on the Warrior is that the click adjuster has larger impact on rebound damping than on precompression. When you increase precomp you increase rebound even more.
Chris Velardi
- Feb 3, 2004
- Killington Vermont
- www.velardi.com
I just ordered the Pro Action Suspension tuning manual and video , I need to learn more on what each piece of the suspension setup purpose is and when changing those settings what can be expected . After this past trip to Groton State Forest in VT , I'm fining my suspension a little to harsh (of course it would have helped if they gromed more often.
