QCRider
- Feb 27, 2004
- Seacoast Region, New Hampshire
- www.myspace.com
Well, they don't rust, that's all I know for sure.
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
I too read somewhere that they are SS but mine do appear to have just the slightest amount of rust. Similar to the coating of rust the clips get. Washed off within the first few seconds of riding anyway
I rememeber installing the first set on my Warrior. I left the track tight and was having a bear of a time rotating it by hand. Once the installed ones hit the front curve of the hyfax the free wheeling feel was incredible
Once fully installed I could set the #*$&@ end of the sled on my shop floor and with the ski's on casters could push the sled with one finger to get it to roll. I actually found this out by accident; When I dropped the #*$&@ end of the sled down after installing the pads I sat down behind the sled to pickup the tools I was using, I grabbed the rear grab bar to lift myself up and the sled slide away from me and on my face I went
ViperTurboPete
- Mar 25, 2005
- Sudbury, Ontario
- 2015 Viper XTX LE MPI Turbo
2022 Expedition Extreme 850
Are there any Canadian distributors (Ontario preferrably) or do I need to order from SLP directly in the States?
sinjin
How far does the bolt on these protrude through the track.
QCRider
- Feb 27, 2004
- www.myspace.com
Not much more than the nut that you thread onto it.
Mark O
Bob Miller said:They are not Stainless but Plated!
Looking at them in my hand, they are definately plated, not stainless.
Yama-Crazy
- Jan 10, 2005
- S/E Michigan
- 2014 Yamaha Viper rtx
Ok so its official I cant find anything that says different. Anyways I would not use a elevator bolt...I would drill the 1 and 1/8 inch holes 1st, the elevator bolts would be not very effective with no dome shape to them and a carriage bolt is too much dome and not wide enough and not a much cheaper route THE END.Mark O said:Bob Miller said:They are not Stainless but Plated!
Looking at them in my hand, they are definately plated, not stainless.![]()
Him
- Mar 10, 2004
- Sweden, the northern coast...
- Sweden
- Apex -11 MCX290
RX Warrior -04
Yama-Crazy said:Ok so its official I cant find anything that says different. Anyways I would not use a elevator bolt...I would drill the 1 and 1/8 inch holes 1st, the elevator bolts would be not very effective with no dome shape to them and a carriage bolt is too much dome and not wide enough and not a much cheaper route THE END.![]()
I've done about 5000km on carriage bolts and they still work very well and the hyfax hasn't been damaged by the dome. So I don't think it's to much dome, and it cost me $5 for a complete set to a 136"
Yama-Crazy
- Jan 10, 2005
- S/E Michigan
Thats great I'm glad its working for you, and its probally better than nothing... but wider area just like the wider hyfax yammi has gone with means better wear, better performance..I personally would rather spend a few extra bucks and buy something that was made especially for a certain application you usually would benifit from it in the longer run ...you get what you pay for usually falls into play. Also I drilled 5/16 holes in my hyfax to add extra cooling and I would be concerned with the pointier head and less surface area of a carriage bolt IMO.Him said:Yama-Crazy said:Ok so its official I cant find anything that says different. Anyways I would not use a elevator bolt...I would drill the 1 and 1/8 inch holes 1st, the elevator bolts would be not very effective with no dome shape to them and a carriage bolt is too much dome and not wide enough and not a much cheaper route THE END.![]()
I've done about 5000km on carriage bolts and they still work very well and the hyfax hasn't been damaged by the dome. So I don't think it's to much dome, and it cost me $5 for a complete set to a 136"![]()
JDMCRX
- Dec 13, 2005
- OTTAWA, ONTARIO CANDADA
- www.jbauto.ca
any pic of them installed on the sled?
NY_Nytro
- Dec 24, 2004
- Grand Island, NY
- www.gi-snowmobiler.com
ViperTurboPete
- Mar 25, 2005
- Sudbury, Ontario
Bob Miller said:RX1MPete said:Stupid question...where EXACTLY do you drill the hole in the track to install the wear pads??? I am running a 151/2", extrovert drivers with every third window punched out and clipped every third. Does the hole get drilled through the rubber where there is no clip??? Confused....
That is exactly where you put them!![]()
CONFUSED AGAIN! I thought I understood Bob M's reply quite clearly, but now I see NY_Warrior posted a pic where they are installed on the windows. My track has all the windows punched out and clipped every third. I emailed SLP to ask the question if it's okay to put them in the "bar" but haven't heard anything back.
QCRider
- Feb 27, 2004
- www.myspace.com
If your windows are all punched out, why wouldn't you just clip it?
ViperTurboPete
- Mar 25, 2005
- Sudbury, Ontario
RXMountain forum, the guys there say not to clip because of extra weight and difficulty clipping a 2" paddle. So I took the easy way out by not clipping.
SLP's tech info line has been busy all morning.
Mighty
- Apr 17, 2003
- 22 Mach Z
23 Sidewinder SRX
If you cut the window out already Pete don't worry about it then. The pads are there to keep that hunk of rubber you cut out from sticking to the hyfax.
