SledFreak
- Feb 7, 2005
- Ontario. Canada
No one races the mach because you have to be able to shut down the sled at the starting line. The mach Z needs to recycle the electronic valves which means you have to rev it past or up to 7800 RPM and then it is ready to race. You can't do that at the starting line.DoktorC said:Ya..but the F1000 is already a race proven sled in the hands of D&D (you were at haydays right?). I know that's a different sled but the D&D guys already have a setup that works and already have products that make big dyno numbers...As for the Mach..no one races it...It can't compete with a Rev800 or F7 on the grass so I don't see it being a huge acheivement getting an F1000 to run with it....
DoktorC
dirkdiggler said:DoktorC said:Ya..but the F1000 is already a race proven sled in the hands of D&D (you were at haydays right?). I know that's a different sled but the D&D guys already have a setup that works and already have products that make big dyno numbers...As for the Mach..no one races it...It can't compete with a Rev800 or F7 on the grass so I don't see it being a huge acheivement getting an F1000 to run with it....
No I wasn't at heydays. But comparing a race prepped sled to a trail sled is a complete joke. As a racer you should know that. Plus D&D has only had a limited amount of time on the F1000 as a trail sled. I wish we had a crystal ball because I'm betting it gets at least .5 seconds quicker by year three.
The reason the Mach can't run with the f7 or 800 rev in 500 feet is power to weight!!!
I realize the race sled and trail sled is completely different (as I mentioned) but alot of setup and clutching do transfer over....I know of several ISR stock sleds that are also trail sleds.
My whole point was to debate the positive aspects of the mach or F10...just that if the tuning challenge goes to the "pro's" then don't expect the Apex to automatically be the fastest.
Sledfreak - what valves? and why isn't this a factor on the trail?
sandy8657
Don't let Big Moose modify your Yamaha unless you want it to go slower!
There's alot of better dealers who can make your Yamaha alot faster!
SledFreak
- Feb 7, 2005
- Ontario. Canada
The electronic rave valves..... It is a factor. Just ask a Mach guy to go and shut his sled off and then start it back up and pull up to the line and run it. Then run it gain and you will see the difference. Once the sled reaches 7800 RPM and you let off the gas and get back on it. It cycles the Valves to work to there full capacity. It's the main reason no body really races it because you can't let off in a race and you can't rev you sled to 7800 on the stand. I doubdt it would go to 7800 on the stand to cycle them. Great DOO technology.DoktorC said:dirkdiggler said:DoktorC said:Ya..but the F1000 is already a race proven sled in the hands of D&D (you were at haydays right?). I know that's a different sled but the D&D guys already have a setup that works and already have products that make big dyno numbers...As for the Mach..no one races it...It can't compete with a Rev800 or F7 on the grass so I don't see it being a huge acheivement getting an F1000 to run with it....
SledFreak
- Feb 7, 2005
- Ontario. Canada
Or get a Pro that Races Yamaha to tune it like the Cat guys had and the MachZ.sandy8657 said:Don't let Big Moose modify your Yamaha unless you want it to go slower!
YAM182
- Dec 19, 2003
sandy8657-that GT avatar you have is a personal pic of my sled.Its not from Yamaha!
BADSLED
- May 13, 2004
- Syracuse, NY
- 2025 Sidewinder XTX LE EPS
2012 Nytro MC Xpress 270
I have going to the shootout every year and it hurts to watch big moose run their yamahas. These guys don't know much about racing!!!
SledFreak
- Feb 7, 2005
- Ontario. Canada
Ya, I thought something was weird there.YAM182 said:sandy8657-that GT avatar you have is a personal pic of my sled.Its not from Yamaha!
dirkdiggler
Suspended
I will never be the fastest as long as Big moose tunes it and it's down 20 plus hp to the sleds it runs against!!!!
jghastingssr
- Nov 24, 2003
When it comes to times .through the traps with the big dogs, its who crosses the line first..If you can"t run with the big dogs stay on the porch!!! Thirty years of performance sleds i have heard just about every excuse.By the way i run 03rx1,04rxw,06apex,07attak.
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
Good thing those Cats are fast because from the posts on antother site they're having no shortage of problems, both factory and dealer setup. Good thing for them the shootout is a drag race since some aren't making it to 11 miles.
- 22K
- 13K
- 10K
- 6K
