rkkoeb
- Aug 30, 2019
- Green Bay
- None right now
So I notice this year that I need to pump my brake handle a couple times to get the sled to stop. It feels like there might be air in the lines. This didn't happen last year. I putt in a new set of brake pads this weekend and blead the lines. Brake handle was firm but later in the day when I was riding the same thing happen, I had to pump the handle a couple of times to get brake pressure. Any idea on what is causing this?
Check to be sure all lines are tight at the fittings. Not loosing fluid?
rkkoeb
- Aug 30, 2019
- Green Bay
- None right now
If I had a leak wouldn't i see mt brake fluid go down? I will still check
Make sure the disc hasn't warped and is pushing the pads back.
rkkoeb
- Aug 30, 2019
- Green Bay
- None right now
That would make sense i will have to check it out
corrosion on master cyl lid? happens to my atv all the time. had it happen on a sled once.
