MrSled said:TurboJamie said:Tom
Will Yamaha warranty the chain case with the turbo system?
Yes I believe so, it was a bearing failure. I would guess that's why she jumped out of gear on me. I even check it over but did not see the start of it... so those of you that have had them jump into neutral, I would tear it down and really take a good look at that upper jack-shaft bearing.
Also stingray719, to me your post even tho I know you are frustrated with some users... was way over the top and not necessary... all that does is stir the pot.
Which bearing? The jackshaft bearing or the drive axle bearing?
jtssrx said:MrSled said:TurboJamie said:Tom
Jackshat bearing.
MrSled said:jtssrx said:MrSled said:TurboJamie said:Tom
Jackshat bearing.
Was anything else damaged in your case as a result of the lockup? When you say jackshaft bearing I'm assuming the bearing in the case let go not the one behind the secondary?
I'd be inclined to replace the bearing on both ends and I would go out and find a big dollar SKS version just to avoid this issue again. I put a better bearings in mine when I replaced the jackshaft in my procross
jtssrx said:MrSled said:jtssrx said:MrSled said:TurboJamie said:Tom
Jackshat bearing.
It's all trashed. It up to the dealer to do the repairs. I'm letting them do the right thing. Once warranty is over if I still have the unit and I have a problem. I will take care of it on my own. Bottom line is if it falls into neutral then take a closer look at the top bearing in the chain case. I have plenty of great sleds to drive so they need to make the repairs. That's how a warranty works.
brian90
- Feb 22, 2014
Sorry to hear this bad news. I sure hope Yamaha's phone is ringing off the hook and they get everyone fixed up. It seems theres a new problem everytime I get on here.
MrSled said:jtssrx said:MrSled said:jtssrx said:MrSled said:TurboJamie said:Tom
Jackshat bearing.
Good thing you've got one.
TurboJamie
Tom
From past experience in the ProCross arena if you have time over the summer it would be a good idea to pull the case, jackshaft and drive shaft out and check the bearings. The ones used on the cat end are very cheap chineese bearings and did not last very long vs a good quality NTN or SKF. Its worth the piece of mind for you if you take the time. I do not know what Yamaha is using they could have gone with an upgrade I have never had one apart to check.
TurboJamie said:Tom
This is what I was trying to say. Even if the dealer is doing the warranty work I'd still provide a better bearing to the dealer to install
jtssrx said:TurboJamie said:Tom
I understand.... if you would like to drive over to Port Washington and baby sit the process your more then welcome too... I dont have the time and all I can do right now is let them do their jobs...
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
Man reading this post makes me glad I bought the YES for 5 year warrenty on my new 15 viper.
Tom hope you are up and running again soon.
Glad you have back up sleds so no more weekends are lost.
ANy hope our 2015's will be 'fixed'?
Yamadoo
Yamadoo
yamadoo said:Man reading this post makes me glad I bought the YES for 5 year warrenty on my new 15 viper.
Yamadoo
I am not sure why this happened... maybe the chain tension is an issue. I know many people turboed and stock that have way more miles then I do with no problems... not sure what to say other then lets hope no one has an issue and it was a just a few bad bearings in the mix.
YamahaTim
- Sep 21, 2013
- Farmington, MN
- 2014 Yamaha Viper LTX SE MPI Turbo
MrSled said:yamadoo said:Man reading this post makes me glad I bought the YES for 5 year warrenty on my new 15 viper.
Yamadoo
It's weird how I'm not having any chain case or reverse problems, but your not having any of the problems I have had, besides the belt. Kind of inconsistent with the variety of issues!
I hope that no one gets hurt with any of the issues!
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
skip the chain once or pop out of reverse to potentially chip a gear...and that chip to find its way into that bearing to cause havoc!
another theory is it's a long way up to that top bearing...if the lube fill isnt high enough I wonder if the lube doesnt hit that top bearing?
HONDAFIXER
The top drive gear spins on the jackshaft when in reverse. There is no bearing and it wears the gear and jackshaft fast. You must use never-seize when you install the gear on the jackshaft to make it last. Sad thing is you have to do this every once in a while or the lube wears off. Stupid design
yukon yamaha
- Jan 30, 2008
- WHITEHORSE, YUKON CANADA
- 2008 nytro custom! 2014 viper custom
at the top of the chain case on the back side is there not a little elbow fitting with an oil hose on it to drip oil into the top bearing?
