Murse
- Sep 7, 2012
- Cornwall, Ontario, Canada
- 2011 Yamaha Apex Std Red
Why would someone buy a Viper for 250$ more? Are Yamaha clutches worth that? Artic claims to have better clutching and the reviews ( on Snowtrax and Snowmobile.com anyway ) Say that the artic cat has more aggressive clutching. The colors are cool too, I am just curious and wanted to ask the question. Are the XF's having same little issues as the Vipers? Quick search on Artic chat doesn't reveal too much that I can see.
I am bracing for impact on this one....
RXVIPER
- Mar 4, 2010
- Shelburne ,Ont
- 2014 SR Viper LTX
2003 RX-1
The Viper won the Oldforge shootout for stock class ,definitely the better sled. I love mine. Yamaha clutches make belts last forever. Efficiency is free horsepower
Murse
- Sep 7, 2012
Good points.
skidooslayer687
- Aug 22, 2013
- Almonte, Ont.
- 2014 Yamaha Sr Viper LTX SE
Definitely agree on the Yammy clutches, also the Yammy has the manual chaincase adjuster not the automatic one that was problematic with cat... Not sure if cat changed over to a manual one or not.
Same little quirks as ours and they have unproven clutches that I believe are wore out around 3500mi. Oh and the Yamahas are faster out of the box and have a Warranty with no deductible.
Murse
- Sep 7, 2012
A warranty with a deductible???
TestMaster
- Sep 28, 2013
- Alba, Michigan
- www.gdls.com
- 2014 SR Viper LTX SE
2014 SR Viper LTX DX
2001 Venture 600
Given to a friend - 1998 SRX 700s
Buy the AC clutch kit to equal Viper and costs are equal. And still replacing belts more frequently with AC clutches.
Studroes144
Check out my YouTube video of my viper against a xf7000. That should be reason enough right there to choose the viper. That and better clutching and cheaper belts and more stylish design. Yes they are the same sled but the viper has a lot more detail than the cat
Murse
- Sep 7, 2012
YouTube Link?
TestMaster
- Sep 28, 2013
- Alba, Michigan
- www.gdls.com
2001 Venture 600
Studroes144 said:Check out my YouTube video of my viper against a xf7000. That should be reason enough right there to choose the viper. That and better clutching and cheaper belts and more stylish design. Yes they are the same sled but the viper has a lot more detail than the cat
And those races were before your clutch kit and studs.
Studroes144
Just type in Barry Roes in the search bar on YouTube. And yes both sled are 100% stock. No clutching done on either and no studs on either. Did some temp tests after 6 runs and the belt and secondary on the cat was 20 degrees hotter than the viper and the primary was a few degrees hotter on the cat as well. After letting sit for a few minutes the viper belt and clutches cooled down a lot and the cat clutches and belt only dropped a few degrees. I hope for the cat guys that they don't have belt issues because both the viper and 7000 are awesome sleds but I'm thinking now that people are getting some decent miles on them that the belt issues are going to start showing up
Murse
- Sep 7, 2012
I see that on the Yamaha Canada site the shocks are hpg shocks in the rear and the 7000 has Floats in the rear. If this is correct that is much better for me as I hear a lot of negatives about the rear mega float.
journeyman
- Nov 27, 2005
- Prior Lake, Mn.
- 2007 Attak GT
- Prior Lake,MN
On the premium models I thought I read the Yamaha has Fox Float 2's and the Cat has FF 3's. Not sure what the difference is. Maybe someone can clarify that.
Studroes144
Vipers and the cats both have the float 3 shocks on the snopro/se models. To my knowledge the xf7000 and viper ltx had identical rear skids and shocks but could be wrong.
FAMILYMAN
Xf7000 is green. That's a -250 loss in value.
