newtron
- Jan 2, 2010
- 2020 900 ACE Turbo, 2019 SRX, 2018 850 X
Curios which Daltons you have and what the total weight is. What RPM were you hitting?
Dtya-1 weights. Running them empty right now. 73.6 grams.
Running 9100 - 9300 rpm right now. Great conditions
Shagnos
- Jan 23, 2007
- Slowville mi
- Sidewinder
Make sure all magnets (as in each separate hole) are facing the same way polarity wise....if you're tips magnets are + outside and the inner hole magnets are - out, you're gonna lose some magnets, the vibes will make them walk out.
Did not know this but it makes sense. Good info!
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Hi I am only going off what my buddy who rebuilt my sled for me,told me he had seen,and it was going thru wind blown lake bumps on the small lake,he said all he could see was 100 speedo,but that was with just 3-4 second blasts. My feeling is now with new roller secondary on its torsional secondary,may be backshifting more than you think by hitting them 3 foot snow banks one right after the other.He also said it was only pulling 8900 and allen wants it at 9100-9400,but it is geared yp 3 teeth on bottom,also may be a cause for lower rpms,and it only now 40 miles.Dtya-1 weights. Running them empty right now. 73.6 grams.
newtron
- Jan 2, 2010
I'm not sure what you're talking about. Party on dude!!
Fleecer
- Jun 13, 2014
- 2019 SRX
How much power is Evo Stage 4?? 280?
PowderFalcon
Pinnin' it!
- Jan 29, 2007
- Drumbo, ON
- 2021 Sidewinder SRX
Their website says 79hp over stock. I believe their base dyno was 187. = 266hp.
Fleecer
- Jun 13, 2014
- 2019 SRX
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Stage 4 is 58 HP over stock, not 79.
https://evopowersports.com/product/ecu-programming-with-maptuner-x
scuba_nytro
- Feb 1, 2011
- 2009 Nytro RTX MPI Stage 1, Hindle Exhaust, Evolution Re-flashed ECU, Ulmer Clutch Kit, Split Rail Skis, etc.
Says Stage 4 is plus 71hp on this
KnappAttack
- Feb 19, 2004
- Welch MN
Interesting, yet click on the link I provided above it says 58 HP over stock at 14.8 lbs of boost right off their website, (Don't know how to do a screen shot on the computer) wonder what has changed? Obviously the boost is higher above on that dyno sheet by 1.2 lbs. so HP is up accordingly. Maybe an change to the stage 4 tune over time.
1100saber
- Dec 17, 2016
- northern ontario
- 2017 Sidewinder LTX-SE
- AlliedPerformanceShoppe@outlook.com
The 16 psi is original stage 4. Look at date on graph. They dialed it back to 14.8 psi.
Doowithblue
- Mar 17, 2016
- Waterloo ON
- 07 Mach z x (sold)
18- RTX LE
Now that's even more confusing. Maybe evo can chime in here?
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Yes w/CAI around 270 I was told,have not ridden it yet.How much power is Evo Stage 4?? 280?
