Stage 4 evo tune on the lake
Curios which Daltons you have and what the total weight is. What RPM were you hitting?
Dtya-1 weights. Running them empty right now. 73.6 grams.
Running 9100 - 9300 rpm right now. Great conditions
Make sure all magnets (as in each separate hole) are facing the same way polarity wise....if you're tips magnets are + outside and the inner hole magnets are - out, you're gonna lose some magnets, the vibes will make them walk out.
Did not know this but it makes sense. Good info!
Hi I am only going off what my buddy who rebuilt my sled for me,told me he had seen,and it was going thru wind blown lake bumps on the small lake,he said all he could see was 100 speedo,but that was with just 3-4 second blasts. My feeling is now with new roller secondary on its torsional secondary,may be backshifting more than you think by hitting them 3 foot snow banks one right after the other.He also said it was only pulling 8900 and allen wants it at 9100-9400,but it is geared yp 3 teeth on bottom,also may be a cause for lower rpms,and it only now 40 miles.
I'm not sure what you're talking about. Party on dude!!
How much power is Evo Stage 4?? 280?
Says Stage 4 is plus 71hp on this
Interesting, yet click on the link I provided above it says 58 HP over stock at 14.8 lbs of boost right off their website, (Don't know how to do a screen shot on the computer) wonder what has changed? Obviously the boost is higher above on that dyno sheet by 1.2 lbs. so HP is up accordingly. Maybe an change to the stage 4 tune over time.
The 16 psi is original stage 4. Look at date on graph. They dialed it back to 14.8 psi.
Now that's even more confusing. Maybe evo can chime in here?
