Deeppow16
- Oct 19, 2015
- Montrose, Minnesota
- 2016 Arctic Cat M8000
2002 Polaris 600 XCSP (Sold)
Well last week my starter crapped out because my relay crapped out, starter is froze and the new relay just clicks. So now I'm doing this fun job of removing it. I don't have any questions about getting the starter out. My question is when I look on online at new starters I see some that are $100 and some that are $350 but all say I can use them in my nytro. What have people used for starters? Aftermarket or OEM? Thanks in advance.
Jobber starters are not worth the scrap metal they are made from.
Deeppow16
- Oct 19, 2015
So go with OEM is what your saying?
![](/styles/admin.gif)
![](/styles/vip.gif)
I know a guy putting one in that he bought off Amazon.. I hope it lasts more then a year. A new one is crazy priced.
herndonp
This might save you some time. http://www.rays-shop.com/2011/04/the-easy-way-to-replace-a-yamaha-nytro-starter-motor/
Pete
Pete
Pete
Thats the way I do it.
herndonp
If the starter looks in good shape may just need to replace brushes Ref# 2 In diagram below. ($36)
RobWarrior
I added a little twist to those instructions that allowed me to do the job alone and not use pry bars potentially doing more damage. If you have a snowmobile lift you can follow his instructions to the point where you pry the engine up to let the starter fall out, from there raise the sled up as high as possible on the lift, you need an eye bolt in your ceiling and 2 ratchet straps, hook them to the eye bolt and the castings holes on the motor, lower the lift slowly and the starter will drop right out, install the new one and raise the lift until the mount holes line back up.This might save you some time. http://www.rays-shop.com/2011/04/the-easy-way-to-replace-a-yamaha-nytro-starter-motor/
Pete
Might be doing this again as my starter is acting up.
Deeppow16
- Oct 19, 2015
Yeah this is the way that I'm doing it. Now I just need to find a couple buddies to help pry the motor with me.This might save you some time. http://www.rays-shop.com/2011/04/the-easy-way-to-replace-a-yamaha-nytro-starter-motor/
Pete
Deeppow16
- Oct 19, 2015
I like this idea. Might have to try it before I try prying on it.I added a little twist to those instructions that allowed me to do the job alone and not use pry bars potentially doing more damage. If you have a snowmobile lift you can follow his instructions to the point where you pry the engine up to let the starter fall out, from there raise the sled up as high as possible on the lift, you need an eye bolt in your ceiling and 2 ratchet straps, hook them to the eye bolt and the castings holes on the motor, lower the lift slowly and the starter will drop right out, install the new one and raise the lift until the mount holes line back up.
Deeppow16
- Oct 19, 2015
Thoughts on this Kimpex starter? Its have the price of a Yamaha starter.
Deeppow16
- Oct 19, 2015
Looks like I found the problem. A huge piece of the magnet broke off and the magnet actually spun about 3/4" around in the housing. I wonder how that happened!
RobWarrior
I used a DB Electrical, I would go with this Kimpex or maybe a Rick's motorsports one now...with that said the DB is still ticking. I thought I was going to need to change it again but turned out my battery was weak. 3 years about 2000 miles with the DB.Thoughts on this Kimpex starter? Its have the price of a Yamaha starter.View attachment 135758
Prior to that was it tough to start?
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
I've installed DB Electrical starters also and as far as I know they are all still out there working. Make sure you replace the starter relay when doing a starter replacement.
