yam177
- Aug 14, 2008
- Shoreview MN
- www.jbeurotech.com
Just be carful that oil tank is brittle don't over torque that plug
Thanks RedPhazer......How about the coolant or anything else I should know before I start unplugging hoses?
Can these starters be rebuilt? Or can I use a non-OEM starter?
I just talked to the starter rebuilder shop locally and they said most can't be rebuilt and he is checking on a replacement starter that might be non OEM.....any thoughts?
Thanks yam177 for the advice, I can always use little tips like that...those are the things that cause you to throw things and cost you an extra $250 ...
Where do you guys find all the tolerances and torque specifications? It seems like around the forum people throw them out every now and then..
yam177
- Aug 14, 2008
- Shoreview MN
There is a PDF of the manuel somewhere on here. I just go by feel but I have been an Auto mech for 15 years. Certain things I torque but things like an oil drain plug I just feel
Reaper
- Nov 10, 2005
- Starbuck, Manitoba
- 2014 SR Viper XTX. COTC, Hygear 141 pro link.
Looked hi and low in the manual and could not find torque spec for bolts that secure the front clip to the bulkhead. Anyone know?
marpolsdofer
I remeber it was not much, not even worth pulling out a toque wrench. Just snug it becaues the expanding and contracting it does is goint to make it tighter.
Reaper
- Nov 10, 2005
I did them at 20 ft lbs.
Hope I did not pull out the threads.
marpolsdofer
I think it was 11 and 13 ft lb.
Reaper said:I did them at 20 ft lbs.
Hope I did not pull out the threads.![]()
I snugged mine up pretty tight. Probably more than 20lbs. I think you'll be fine.
Reaper
- Nov 10, 2005
I talked to the guys at me Yamaha dealer and they said 20-24 ft lbs and yes blue locktite of course. They have had a few with bolts falling out.
I have the starter out and I am putting the new one in...which wire connects to which terminal on the starter?
I need to line up the line in the starter with the little protrusions on each end of the starter right?
The dealer took out the starter and I didn't want to pay them the $600 they wanted to put it back in and replace it at full retail price (in case you are wondering why I didn't check the wires before I removed it
Holy Cow!Its been awhile but big red one goes to the copper colored post and the other black one goes to one of the starter mounting bolts
- 6K
