Snow trackers should be in today, I rode them so far with about a 3mm homemade shim in the back which is the way I ran my tuners so the ski sits just a tad tipped up. Using a 1/2 worn set of dullies from a chum and so far the thoughts are. Lighter steering, zero darting with a little push when being aggressive but i have about 11 turns up from contact on my stock front skid spring which I could lower and surely take out alittle of the push but its not bad at all and predictable. So far this season with the tuners it would hook and lift the left ski with almost ever left turn, swapping carbides and playing with independent ski pressures did not fix it.. well, that is gone, corners equally now. I could live with this setup..
Today I'm installing the cat 2704-229 cat skid spring and my snow trackers, pending delivery. Ill check but not touching my toe yet.. stryke skis are about an inch wider which is a bonus as I still use my 300hp srx for pulling a fishing sleigh, hahaha. On 270 though... careful on the semi st # roaming on this site; its not the proper trackers for the stryke. I sent the ones back used here on cat skis and they are def wrong.. ask the guy who has an extra hole and repair on his new skis!!!!
