Jd2859
- Dec 2, 2019
- La Crosse,Wisconsin
- 2020 sidewinder LTX GT
repacked my drive and jackshaft bearings for the year should I repack the stub shaft bearing also? if so can I use the Schaeffers 219 that I used for my drive bearing or is there a different kind of grease that I should use?
Leave it alone. Not sure what’s in Stubshaft bearing but mine has almost 19000mi on it untouched
Depends on miles. If it was mine and you have never repacked this bearing I would change it. I had a ride ruined out with a friend who had a high mile Nytro and this bearing siezed.
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
The seal on that bearing is quite rigid. Its tough to get out without deforming. If you have gone to the work to pull the' shaft assembly' out, youre half way there to press it off and replace.
MS
MS
