Stud sharpening
tttario
Northern Ontario, Canada
OK, I know of the tool that you can attach to a drill and sharpen the tips, but I am looking for the one that will attach to a drill, hold the stud by the head and spin the stud so you can place it against a bench grinder and get them razor sharp. Does this stud holding tool exist or just something that the old timers hand made when i was growing up.
I believe Woodys use to have such a tool,not sure if they still do or not?Now you got me thinking of making one :o|
You don't need to hold it in a drill... try vise grips. No point in spinning the thing fast when the bench grinder is already spinning.
If you can spin the stud with a drill, you will get a more uniform sharpened tip. The tool basically holds the stud like a screw on the end of a bit and spins it, then you place it against the grinding wheel at whatever angle you desire. Works Slick as $hit! Need to find one!!!!!!
