jaydaniels
- Dec 10, 2008
- Bedford NS Canada
- 2017 Sidewinder RTX
Well I put a stud through my cooler. The front cooler by drive axle. Is that a changeable part?
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
Yes it's replaceable. Much easier to pull track and have a good weld shop tig weld it. Will save you a ton of labor!
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
2017 Sidewinder LTX LE
What Travis said. I did this last year. Pulled the rear suspension and track. Threw it in the trailer and took it to a local welder since I got rid of my AC tig machine a few years ago. 20 minutes later back in the trailer and off I went. Only charged me 60 bucks.
jaydaniels
- Dec 10, 2008
- Bedford NS Canada
Ok maybe I’ll try that. Mine has a pretty large hole in it. Wonder if that matters? It’s about 1/4” wide and 2” long.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Wow that’s a hole!Ok maybe I’ll try that. Mine has a pretty large hole in it. Wonder if that matters? It’s about 1/4” wide and 2” long.
jaydaniels
- Dec 10, 2008
- Bedford NS Canada
Yeah it’s a bad one. I’m guessing the backer stayed attached and actually hit the cooler.Wow that’s a hole!
J & J Racing
- Jan 30, 2019
- Stillman Valley IL
- 2019 AC TCAT
If it is really big I would consider replacing the cooler
The reason would be for when you sell it. People may shy away if they see that???
Maybe not a concern
Just throwing that out there
Maybe not a concern
jaydaniels
- Dec 10, 2008
- Bedford NS Canada
That’s a good point. Ill decide once I get a price on having it welded.If it is really big I would consider replacing the cooler
Maybe not a concern
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Let us know what the final outcome is. Thanks
Jon
Jon
jaydaniels
- Dec 10, 2008
- Bedford NS Canada
So, I decided to try the welding. Much cheaper and a lot less labour intensive. I hope to put the sled together this weekend. Hopefully I have no leaks. I’ll keep you posted. I also needed a new track and decided to go with the Storm 150.
jaydaniels
- Dec 10, 2008
- Bedford NS Canada
jaydaniels
- Dec 10, 2008
- Bedford NS Canada
possessed
- Apr 18, 2003
- Sidney ME
- 2017 Sidewinder LE RTX 129 Curve Skis 1.0 track header tune 280 hp
08 Apex LTX Yamachager
1998 SRX Bender 835
03RX1/ 1993 Thunder Cat
- YAHOO
- rx11000@yahoo.com
Ouch that sucks I ran a 1.6 track didn’t like it great in deep snow but not a good track for groomed hard trails spun to much and lost a lot of top end !!!Im now running a 1.22 ice track a lot more traction!! Just my two sense!! Good luck !!My track
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- Sacandaga reservoir
That sucks
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Weld it.
Exactly why I don't use long studs or tall nuts. I'd rather the stud bend than rip out if you catch something.
Also the reason I prefer double backers, exactly twice the holding power and ability to stay in the track.
