Traildemon
Found a new ripsaw track at a local swap meet for my 03 RX-1. I want to stud 144 - 1.40 in. down the middle. there shouldn't be any clearence issues right ? , looks like there's plenty of room ?
Yamadog
The 1.40's are a bit long I think they reccomend 1.325's but I have a 1.25" shotgun with 1.325's on the drive shaft and waiting on my bender RA suspension upgrade. no there hsould not be a clearance issue as lon as your stud pattern doesn't hit the tunnel protectors. You want the rubber nubs to make contact with them.
gradzz
I just finished putting 144 down the middle on mine with 1.375 and there doesn't appear to be any clearence issues.
rxbrent
studs
It depends on which brand you run. I run the extreme max 1.40 down the center with no problems.
meklke
144 down the Middle
What major disadvantage is fully studding the track vs "down the middle?
glred
Stud the ouside band and they will rip out guarenteed, 144 down the middle is the way to go!
Grimm
Re: 144 down the Middle
Worst case scenario, you'll puncture the heat exchangers.
meklke said:What major disadvantage is fully studding the track vs "down the middle?
sledheadgeorge
It also makes the sled harder to turn.
tshelver
Had a fellow RX1 rip an outside stud last year, took out the heat exchanger. Fortunately we picked it up at a rest stop, and not out on the Chibougamau trail where he was headed next.
Still marred the ride for the rest of us. IMHO, studs and LD remote trail riding aren't that good an idea, especially where they can rip out of the track.
meklke
144 studs
For what it is worth, Hauck Power Sports in Rice Lake WI recommended 144 studs with 96 down the middle and the rest on the outside (every other side).
MOTOWN SPEEDFREEK
I put 192x1.52 studs in the center of my 1.25 ripesaw track.HOOKS UP GREAT!!1 can still throw it around in the corners.
- 42K
