Dynomax666
Does grizz still do the gusset kits haven't seen a lot of recent posts. Does he straighten and weld it up? Or just sell the kits? Im Not risking this getting bent again.
Keith1962
- Mar 26, 2015
- Camillus, NY
- 2009 Nytro XTX,OFT Relocator, Excell exhaust, Curve Skis, Excell wheels, Dupont Slides. Star Suspension. Hygear Billet rear shock and spring spacer. Air Box Mod. Clutch mods, Polished tunnel. Custom GPS mount. BOP Skid Plate. RSI handwarmers.
Send him an email. grizztracks@gmail.com
Gone Blue
- Oct 11, 2006
- Howell, Michigan
Grizz just sells the kit. With the sled sitting on the garage floor on the skis, I used a 3 plus foot crowbar to straighten my tweaked subframe. Then tore it down to weld in Grizz's kit.
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
I'm still around if you need help with the subframe. grizztracks@gmail.com
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
I need a gusset kit.I'm still around if you need help with the subframe. grizztracks@gmail.com
I'll email you.
Tim
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
Hooked a carbide last spring...
Going about 10mph across tracks.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
Installed my gusset kit after straightening the subframe.
Thanks grizz!
Check out this lower ball joint that got bent.
A arms did not bend.
Sub frame is super strong now.
Thanks grizz!
Gone Blue
- Oct 11, 2006
- Howell, Michigan
1nc 2000, that is bad azz! I installed Grizz's reinforcement kit 4,000 plus miles ago and I knew once welded, it would be stout! G.B.Installed my gusset kit after straightening the subframe.
Thanks grizz!
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
New ball joint on the way from speedway motors and should be ready to go soon.
