Malibu said:Ohhhh......my arm hair got longer than everdoes mpi have a kit??do you know how much power?
This is MPIs kit except for the PCV and Auto Tune... not sure on the HP... some place around 200 HP.
yamaha1973
- Nov 27, 2011
- St. Peter Minnesota
- 2014 Viper XTX SE
sounds great!
Well after this last weekend, I have made more progress in the Super Charger and Auto-tune.... running good now , steps in the right direction finally.
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
Sled how does this sled run for you now? You sure went through a lot but hopefully you got it dialed in.
kinger said:Sled how does this sled run for you now? You sure went through a lot but hopefully you got it dialed in.
She is running really really well. The Map still needs some tweaking but it sure nice to know exactly what the machine is doing and how I can make it better... I learned a ton on this project.
sheetwright
- Jul 7, 2008
- Northwoods USA
- 2021 Yamaha SRX
Wish you good luck. Been through this twice with my last Nytro and it is nothing but an expensive process to fine tune that addictive power. You definitely have more patience then me. Two motors and two lost seasons on her and I started over at a bit lower boost on a newer model. Good luck hope she is finally dialed in
sheetwright said:Wish you good luck. Been through this twice with my last Nytro and it is nothing but an expensive process to fine tune that addictive power. You definitely have more patience then me. Two motors and two lost seasons on her and I started over at a bit lower boost on a newer model. Good luck hope she is finally dialed in
Thanks, it has been a painful process... I was almost going to stop but I had to try one more time...LOL, Your right it is very addicting.
- 9K
