eightpilot
- Mar 17, 2009
- Mosinee WI
- 2021 Thundercat
- Mosinee WI
Is anyone running a surge tank on these Winders? Below half tank my sled is running lean on boost. I know this was a week known problem with the 2012-16 Procross Cats.
![](/styles/vip.gif)
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
They have an internal surge tank in them stock.
I don't see any change in AF with full or low tank myself. How much change in AF are you seeing?
eightpilot
- Mar 17, 2009
- Mosinee WI
- 2021 Thundercat
- Mosinee WI
Full boost it goes from 12.3 to 17+... doesn’t do it with the tank full tho.
eightpilot
- Mar 17, 2009
- Mosinee WI
- 2021 Thundercat
- Mosinee WI
I’m losing fuel pressure somewhere because when it goes lean you can feel the boost fall off.
KnappAttack
- Feb 19, 2004
- Welch MN
Thats not right or good to hear at all. How long are you in the throttle before it runs out of fuel like that?
I've had it happen with my old 1200's where they needed a surge tank and run out of fuel below half tank.
First I've heard of this happening on a Winder. Which tune and did it do it stock?
eightpilot
- Mar 17, 2009
- Mosinee WI
- 2021 Thundercat
- Mosinee WI
I cut the throttle as soon as it happens.
KnappAttack
- Feb 19, 2004
- Welch MN
Right but how long are you in the throttle when it happens? till 80? 100? What.
And what tune? 12.3 even sounds leaner than normal.
eightpilot
- Mar 17, 2009
- Mosinee WI
- 2021 Thundercat
- Mosinee WI
ECO tune and it happens fast. Maybe 3-4 seconds after full throttle is applied.
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
2017 Sidewinder LTX LE
Call Ben. Something isn't right.
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
Maybe the front check valve thing on your pickup fell off?
eightpilot
- Mar 17, 2009
- Mosinee WI
- 2021 Thundercat
- Mosinee WI
It’s been bumpy as hell. So anything is possible.
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
![qumqslm3.jpg](/proxy.php?image=https%3A%2F%2Fs15.directupload.net%2Fimages%2F190105%2Fqumqslm3.jpg&hash=94efe08a2752a5320c8ea5c374603f2b)
#30
Tarzan
- Oct 28, 2009
- Norway
- www.youtube.com
- Norway
Yes i run a catch tank,i have no more problems with lean with just 2 markers left on fuel in gauge. ![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
eightpilot
- Mar 17, 2009
- Mosinee WI
- 2021 Thundercat
- Mosinee WI
I can clearly see the surge tank in the diagram. I shouldn’t need anything else. Ran fine for 100 miles today. But later in the day it started acting up. Gonna due what Ben suggested and have him send me new tunes. Waaaay to many issues with this bundle.
Mototown
Mine was cutting out when I do standing starts , with anything under 1/3 of a tank . The two pick ups , one was not laying in bottom of tank , had to reposition it . # 30 on diagram. If you hammered through a really rough trail they must bounce around.
