DooZ
- Feb 26, 2007
- Minocqua, WI
- ZR9000RR
Doo 1200
Here's a spring I found that may offer some benefits if the green is a bit much in the Pro4/Stm driven https://boostkinetics.com/shop?olsPage=products/arctic-cat-torsional-secondary-spring-100150-free-shipping
More of a fine tuning change vs drastic change from green to red/white
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
yea that spring is probably similar to the EPI purple, and is what I’ll have to settle for fer now.
DooZ
- Feb 26, 2007
- Minocqua, WI
- ZR9000RR
Doo 1200
Not familiar with the EPI purple, but it must be close to the D&D purple https://shop.ddracing.com/d-d-powersports-llc-d-d-secondary-springs-detail.htm?productId=-405389yea that spring is probably similar to the EPI purple, and is what I’ll have to settle for fer now.
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
@ 2 1/2" @ 1 7/16"
Dalton white 98 165
Cat green 96 157
EPI purple 86 148
Cat red/white ??? 116
I cant find the start rate for the CAT red/white but the finish is pretty low
Dalton white 98 165
Cat green 96 157
EPI purple 86 148
ISLANDRACING
- Dec 15, 2005
- NEW YORK
- www.islandracing.net
I found the specs for the RED/WHITE 68/116@ 2 1/2" @ 1 7/16"
Dalton white 98 165
Cat green 96 157
EPI purple 86 148
Also some specs for the D&D springs:
D&D Grey 67/123
D&D Purple 83/140
showtime
- Sep 16, 2016
- New Brunswick
- 09 turbo cat
Very good info ,i have hurricane ss tunes ,tapp and stm with button cover instead of roller ,only diff . is i have 9000 2017 cat .
showtime
- Sep 16, 2016
- New Brunswick
- 09 turbo cat
Have tapp black spring, number 2 rollers, set on a on cam, 3 on clickers, 52\44 with purple in centre hole on stm ,xs825 , pulls 8900 0n 285 stock muffler tune ,happy with set up
STAIN
- Feb 29, 2004
- Vermont
- Vermont
Wow. Surprised you can pull RPM with that set up. More to consider.....Have tapp black spring, number 2 rollers, set on a on cam, 3 on clickers, 52\44 with purple in centre hole on stm ,xs825 , pulls 8900 0n 285 stock muffler tune ,happy with set up
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
steeper angle, spring pressure balance, not pressuring a flat angle causing super squeeze on belt .
STAIN
- Feb 29, 2004
- Vermont
- Vermont
Is that the EPI purple secondary spring?with purple in centre hole
THEPASMAN
- Mar 25, 2019
- The Pas Manitoba
- 2017 Sidewinder LTX LE
Where does the dalton B/O fall in that line up of springs. Also the stock yellow. Just wondering
Thanks Brent
Thanks Brent
J & J Racing
- Jan 30, 2019
- Stillman Valley IL
- 2019 AC TCAT
Remember this is a button coverWow. Surprised you can pull RPM with that set up. More to consider.....
Can pull probably 4 degrees more than roller or so
Still 40 finish with roller
I liked 38 to 40
showtime
- Sep 16, 2016
- New Brunswick
- 09 turbo cat
Thinking dalton ,come from HurricaneIs that the EPI purple secondary spring?
STAIN
- Feb 29, 2004
- Vermont
- Vermont
That makes a little more senseRemember this is a button cover
I liked 38 to 40
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
EPI purple secondary spring comes from Erlandson Performance.
It is NOT a Dalton spring. Dalton has a Cat white which is the exact spring as a Cat green, both of which is a bit more pressure than the EPI purple.
- 7K
- 43K
