Pro4 clutch
Other than the current arctic spell it never go started here. Lowest snow fall in 30 plus years.
Terry, you may want to post that nice video you have of this clutch and the easy adjusting ect....
Also, I believe Terry mentioned Dalton weights(which most of us have in our stock primary) will fit into the pro4.
Dan
Clutch looks good being a 3 arm, have you heard or tested if there is any harmonics setting off knock? Like STM 3 arm? I am interested in buying one but I want to make sure. How much does it weigh? Thanks
I haven’t had any problems...i believe it weighs the same as the AC team primary.
Nospro to install on AC 9000 what belt and different clutch puller?
Install on 9000 the same as the winder, 105 ft. lbs. to seat the clutch, back off and then 48 ft. lbs.
To remove the clutch requires a special puller from Pro 4 Performance.
Belt, you can run whatever belt you wish and the clutch will be setup for that belt. Most of the winder guys are running the stock 8JP or 8DN
Do you have these in stock?
Can I run the wider cat belt? Don’t care for the narrower belt, See nothing on your web site, how do you order?
Also consider the Tapp, it's a four arm with no weights or spring to buy separately for $1400. I have approximately 4500 miles on it and it's still tight everywhere. Food for thought
Oh he is because this is what his Team looks like
