sledding rocks
- Feb 11, 2017
- north
- sidewinder
do u have to have stage 6 to run the td big turbo ? im on the fence with the modstock or big turbo ,
justinator
- Mar 25, 2007
- Maine
- 2023 Arctic Cat Riot 9000
Theres a list of suggested additions and requirements for the big turbo on the td website.
Copy and pasted from td website:
to review do not use TD stage 6 if you plan to run the TD GAP big turbo kit on the trail on pure 91 octane (you can use 91 + c16)
Stock cams are best for 91 octane pump gas trail use on the TD GAP big turbo kit
For the TD mod stock you can run a TD Stage 6 or stock cams no problem at any boost level.
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
I forgot to mention I have a MS20 stock muffler tune as well for riding in Quebec.What does TD run on their tunes for boost on the big turbo ?
DMCTurbo
- Nov 12, 2005
I havent posted in a while... Too busy wrenching but ended the season with my personal best pass of 152mph out the back door on pump gas, a trail track and trail studs. Happy to be a member of the 150 club! New goal for next year is 160 on pump gas and a speed track.
Fleecer
- Jun 13, 2014
- 2019 SRX
Congrats DMC!! Life is definitely better in the 150 Club!! Lol
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Wow!
Nice work!
Nice work!
0degC
- Jun 5, 2009
- Sudbury, Ontario
- 2023 SRX, 2017 XF 9000
With the lack of snow for trail riding this year been out on the lake more hanging out with DMCturbo and a couple other guys with the big Gap turbo’s. Very impressive turbo even on pump gas, very mid 140s capable in 1320 in trailish form or more.
That's awesome Derek, nice work!
AAdavis
- Sep 30, 2019
- Jackson Wy
- 2020 Yamaha Sidewinder SRX
What intake temps do you see during a pull?
DMCTurbo
- Nov 12, 2005
DooZ
- Feb 26, 2007
- Minocqua, WI
- ZR9000RR
Doo 1200
Did you get into the motor in the off-season to beef things up?
DMCTurbo
- Nov 12, 2005
No I did not.Did you get into the motor in the off-season to beef things up?
Turboflash
- Mar 18, 2019
- Southern MN
RPM is climbing. Ever think about adding about 2 more grams to tip? Shouldn't you want closer to 8900? Maybe 9000?
DMCTurbo
- Nov 12, 2005
94-9500. I'm low on that run.RPM is climbing. Ever think about adding about 2 more grams to tip? Shouldn't you want closer to 8900? Maybe 9000?
Turboflash
- Mar 18, 2019
- Southern MN
Obviously your cams are not same as mine.94-9500. I'm low on that run.
- 22K
- 6K
