Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Oh, nice....the ones on Amazon are $40.Many AFR gages use Bosch LSU 4.9 sensor. P/n 15025 I believe. Can buy them on eBay (genuine Bosch) for about $25.
(https://www.ebay.com/itm/2262472852...cyFCQleRBa&var=&widget_ver=artemis&media=COPY)
My sled has residue but not so easy to tell since it's black.
I was just happy to know, it's the way it is (carbon) I'm not a fan of the discoloration. Even tried Wesley's bleach white. I'll follow Bob's recipe to Solve that problem.
Gives me one less thing to worry about.
PowderFalcon
Pinnin' it!
- Jan 29, 2007
- Drumbo, ON
- 2021 Sidewinder SRX
Mr. Clean magic eraser for the black soot on your panels fellas!
Simplespeed
- Jan 8, 2022
- 1191 Sauk Lane , Saginaw, Mi. 48638
- 2006 Apex , 2017 Sidewinder LTX -LE
For cleaning on your sleds try a product from Boaters World called Roll Off .. Its the best cleaner I found to work on original decals and works even better if you keep wax on them beforehand..
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Hey Bob. Wondering if heat shield you put on is still working for you? Other thing I see is you installed it with the shiny metal side UP. Guessing you did this so it was not metal on metal? I have this same stuff and doing a mod, and was wondering if this set up is holding up?I would suggest protecting the cooling hose from header heat.
The heat protector suggested by KnappAttack in this thread is what I have used and it has stood up well.
Looking for a Mid pipe heat shield
Looking for a used or new mid pipe heat shield. I got 10,000 miles out of the original but the eyelets finally came out of it. Don’t really want to spend $200 for a new one but…ty4stroke.com
Yes I installed it shiny side up. The proper way is to have the metal side to the heat. I never really considered the orientation when I installed it and I installed shiny side out mainly for aesthetics and luckily it is standing up well. The extra shield does not touch the header and there is an air gap between it and the header and also hardly touchs the tank.Hey Bob. Wondering if heat shield you put on is still working for you? Other thing I see is you installed it with the shiny metal side UP. Guessing you did this so it was not metal on metal? I have this same stuff and doing a mod, and was wondering if this set up is holding up?
As you can see in this old thread others have installed the shield in same orientation.
Hurricane Performance header install question
Just finishing installing header on 2020 SRX Sidewinder. Have 1/2 inch clearance between header pipe and fuel tank. Header came with 5 x 5 inch, and 10 x 10 inch of insulating material. I assume the 10 x 10 is installed on fuel tank. Also just wondering what others have for clearance. Any...
ty4stroke.com
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
TY.. Anyone putting any kind of high temp locker/?? on header nuts?Yes I installed it shiny side up. The proper way is to have the metal side to the heat. I never really considered the orientation when I installed it and I installed shiny side out mainly for aesthetics and luckily it is standing up well. The extra shield does not touch the header and there is an air gap between it and the header and also hardly touchs the tank.
Just finishing installing header on 2020 SRX Sidewinder. Have 1/2 inch clearance between header pipe and fuel tank. Header came with 5 x 5 inch, and 10 x 10 inch of insulating material. I assume the 10 x 10 is installed on fuel tank. Also just wondering what others have for clearance. Any...ty4stroke.com
Or just clean up good and torque to 20?
Doc Harley
- Oct 17, 2016
- Here & there
Project huh?!?! Replacing your coolant hoses? Trying to install a weenie roaster in-between the seat & manifold?Hey Bob. Wondering if heat shield you put on is still working for you? Other thing I see is you installed it with the shiny metal side UP. Guessing you did this so it was not metal on metal? I have this same stuff and doing a mod, and was wondering if this set up is holding up?
Things that make ya go hmm?!?!
I just put the manifold bolts in the way they were from the factory at factory torque specs.TY.. Anyone putting any kind of high temp locker/?? on header nuts?
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
I had to make sure you didn't get by me on the lake?Project huh?!?! Replacing your coolant hoses? Trying to install a weenie roaster in-between the seat & manifold?
Doc Harley
- Oct 17, 2016
- Here & there
Well.....back to the drawing board. Hahaha.I had to make sure you didn't get by me on the lake?![]()
I suppose my ported turbo option May come to fruition. Hahaha
Was saving that for next season lol
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
This garage racing is getting old.. Need more snow. STAT. Was the middle LOWER nut on the stock header fun? Is it just as fun with the TD header?Well.....back to the drawing board. Hahaha.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
You're welcome to drive west and we can put your SW on the track dyno, @Turboflash will tell you you'd likely learn alot.
Doc Harley
- Oct 17, 2016
- Here & there
Trust me.....1/4" drive swiveling 12mm. Easy breezy...thanks to Fatchance!! Just sayingThis garage racing is getting old.. Need more snow. STAT. Was the middle LOWER nut on the stock header fun? Is it just as fun with the TD header?
Turboflash
- Mar 18, 2019
- Southern MN
Amen! Until one has done this, you'll not realize how much you don't know.You're welcome to drive west and we can put your SW on the track dyno, @Turboflash will tell you you'd likely learn alot.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Thanks .You're welcome to drive west and we can put your SW on the track dyno, @Turboflash will tell you you'd likely learn alot.
I would love to. But Im holding out for snow first!
Im guessing turboflash is still digesting the info from that trip!
This is him in his garage?
