journeyman
- Nov 27, 2005
- Prior Lake, Mn.
- 2007 Attak GT
- Prior Lake,MN
Measure cracking pressure with a vise grip attached to the driven with a rubber pad under it, then use a fish scale with on the sheave edge.
Guys doing heavier driven springs, old Cat trick that works just as well on Yamaha, put a roll of duct tape on the ground and use your knees to grip the outside of the driven, installing heavy springs is an easy one man job this way.
These higher side pressure springs bring the belt back to the top of the driven like it should and take the ballooning out of the belt. I'm also trying the 8DN this weekend and it too allows it to backshift better with the higher side pressure springs. Throttle response and belt grip in the secondary will be MUCH better. I have a hunch we have been running too light of side pressure in the winders and needing that low angle helix to compensate. My feeling is the lighter driven like the B/O is fine for ice or road running but not enough side force for trail or snow use.
Good info Mike!!
Yep, done the vice grip/fish scale many times!
Good luck on the testing! Gotta get all that power to the ground.
