Thunder Products (Big Venom Viper kit) with Heavy Hitters
Yes they do apexgturbo :)
Just called Thunder Products and they mentioned for you to call them with your specifics...(turbo, naturally aspirated, airbox mod....etc...)
Ok I'll give them a call.thanks.
Just helped another friend install is Big Venom kit :)
Is there anyone who tried the 14,8 mm Thunder shift rollers to the Big Venom kit?
My experience with rollers the 14.8 will put alot more power down out of the hole. Too much in some cases. With heelclickers in the sxvipers upping the roller size was a must. I also ran 15.6 rollers with my heavy hitters in my sxviper
Has anyone tried the venom kit in deep snow? I'm curious how it's going to perform there as well as corner to corner on trails. Any feedback would be welcome!
I will contact Justin who was just out in Colorado with Stingray and other members here. Or @stingray719 could make a comment, would be very helpful as he was there. They had good, deep snow to play in.
I will let Justin reply, but he wasn't slow!
Sorry to interrupt but is anyone running this kit on the snow yet, its already sitting on my work bench, but haven't installed it yet, want to see what and if any gains from 8dn and osp belt adjuster,just like testing my mods one at a time, I miss my nytro xtx 1.75
NOS-PRO and I tested this kit all last winter. It works great in all conditions. You will gain all through the rpm range with increased top end, more low end and mid range pull. Night and day difference from stock.
Thanks, if it pulls as hard as my nytro did I am sure I'll like it.
The viper is great sled right out of the box, but it seems to run out of steam past 70, my 15 ltx dx has 700 miles on it, I know its still breaking in, but I've only hit 88mph so far, I have ulmers intake and the 1.6 ice cobra track on it which I know doesn't help, is this normal, I looked at the clutches and it doesn't look like I have the casting flash issue, don't get me wrong I'm no speed demon or need to be the 1st one across the lake, just want this this to pull hard up to a hundo like my nytro did, hope this kit is the answer.
