swampcat
- Mar 17, 2014
- N. E. Wi.
- 2020 S W LTX-GT
Got-cha, thanks .
- Apr 14, 2003
- Hessel, Michigan
Vilas
- Sep 6, 2014
- Urbana, Illinois
- 2014 Viper xtx, Thunder products clutch kit
So Lonn is out of those small washers that go on the backside of the secondary. Any idea where to get these? I also told him to post your instructional video on his website, I only saw the one showing the low engagement while driving on pavement. Thanks again for all your help! I'm having so much fun working on this sled!You betcha![]()
DranttelSS
TY Advertiser
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
Try your local dealer
Vilas
- Sep 6, 2014
- Urbana, Illinois
Lonn mentioned they were a specific Size but I didn't get a part number from him. Sadly, I have no local dealer as I'm stuck in Illinois and drive 7 hours to do my riding....Try your local dealer
DranttelSS
TY Advertiser
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
If you have a Fastenal or hardware store they should have something that will work. Otherwise give me a call and we can get you what you need.
bleedyamaha
- Sep 28, 2013
- Northern Iowa
take your washer and head to the hardware store.
Vilas
- Sep 6, 2014
- Urbana, Illinois
I should call you guys. I went to college in st. Peter at Gustavus. I graduated just before that crazy tornado.If you have a Fastenal or hardware store they should have something that will work. Otherwise give me a call and we can get you what you need.
DranttelSS
TY Advertiser
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
Small world!
- Apr 14, 2003
- Hessel, Michigan
You are very welcome Vilas!
I have to call Lonn today and inform him to get the videos posted to his site
Like DranttelSS mentioned, you can get them at a dealer or you can do like bleedy mentioned, take your bolt out, bring the washer and the bolt to your local hardware store and find 3 washers that are about the same thickness that fit on the bolt. Should be roughly .050" thick. Purchase 3 washers and then place that washer on the bolts followed by the original washer. Your setup should be bolt + 1 hardware store washer + stock washer and then screwed back into the secondary. Total of 2 washers per bolt. (I put the hardware washer on first cause sometimes the hardware washer can be a slightly bigger diameter and rub the area close to the bolt or bind) Just an FYI
Vilas
- Sep 6, 2014
- Urbana, Illinois
Great suggestion thank you very much. I spoke with Lonn on the phone the other day because I had a questions and I did tell him about the instructional video and he said he'd look into it. When you click on the Big Venom kit, you only see the one video and I think both should be on there. Your instructional video was spot on and it made the install super easy!You are very welcome Vilas!Glad to help out
I have to call Lonn today and inform him to get the videos posted to his siteHe has them, probably crazy busy....LOL
- Apr 14, 2003
- Hessel, Michigan
yamaha06
Is it worth getting the gates belt over running the 8DN?
Give me a link to that video and I will add it to first page of the thread.Great suggestion thank you very much. I spoke with Lonn on the phone the other day because I had a questions and I did tell him about the instructional video and he said he'd look into it. When you click on the Big Venom kit, you only see the one video and I think both should be on there. Your instructional video was spot on and it made the install super easy!
Vilas
- Sep 6, 2014
- Urbana, Illinois
Here is the YouTube link
