DIwarrior
- Oct 22, 2003
- Drummond Island MI
- 2025 SRX LE #473
2025 SW XTX LE
2025 SW LTX GT
2001 SRX
1968 Ski-Doo
- Drummond Island, MI
- Nope
I’m looking for advise on the best setup for the stock Tuner III’s on a Sidewinder ridden exclusively on groomed trails in the U.P. I am running an Ice Attack 1.22 so it is mildly studed. Most of my research here on Tuners, the threads end up morphing into what aftermarket ski is better. I’m not willing to spend another $500 to $800 for a set of skis. Just want to make the stock ski as good as possible. I am currently running Woodys 6” on the inside and 4” on the outside edges.
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
Describe your handling "problem" to get more direct advice. What don't you like about your handling?
Ynot
- Jan 10, 2019
- Sudbury
- 2019 Sidewinder SRX LE
I put 6" inside and outside it helped a little.I’m looking for advise on the best setup for the stock Tuner III’s on a Sidewinder ridden exclusively on groomed trails in the U.P. I am running an Ice Attack 1.22 so it is mildly studed. Most of my research here on Tuners, the threads end up morphing into what aftermarket ski is better. I’m not willing to spend another $500 to $800 for a set of skis. Just want to make the stock ski as good as possible. I am currently running Woodys 6” on the inside and 4” on the outside edges.
Brake into the corner and braaaap out of it
DIwarrior
- Oct 22, 2003
- 2025 SRX LE #473
2025 SW XTX LE
2025 SW LTX GT
2001 SRX
1968 Ski-Doo
- Nope
Mostly hard steering and excessive darting on hardpack trails.Describe your handling "problem" to get more direct advice. What don't you like about your handling?
SAB1
- Mar 1, 2011
- Tuftonboro NH
- 2017 Sidewinder LTX SE
2010 Vector GT
2006 Apex
So you must not have Steve OCD's writeup on Semi Aggressive Snotrackers
he swears by them now and off season I will likely purchase that. I can also tell you my buddy is running 8" Qualipieces square bars on the inside and stock outside and loving them. He corners great. Rides hard (not a hard as Steve though!) I saw a thread somewhere else where a guy running the Qualipieces swore by them.
actionjack
- Apr 9, 2005
Tighten front skid shock pre-load a little at a time and test until you have a balance you like.
You can try lengthening the limiter strap also but I would start with the front skid shock.
I ran Snowtrackers on my MTX skis and they made VERY light steering but had too much push even after shortening the limiter strap. Tried both semi-aggressive and Agressive preferred semi-agressive on that ski (not the same at all as Snowtrackers on Tuners).
DIwarrior
- Oct 22, 2003
- 2025 SRX LE #473
2025 SW XTX LE
2025 SW LTX GT
2001 SRX
1968 Ski-Doo
- Nope
DIwarrior
- Oct 22, 2003
- 2025 SRX LE #473
2025 SW XTX LE
2025 SW LTX GT
2001 SRX
1968 Ski-Doo
- Nope
So you must not have Steve OCD's writeup on Semi Aggressive Snotrackershe swears by them now and off season I will likely purchase that. I can also tell you my buddy is running 8" Qualipieces square bars on the inside and stock outside and loving them. He corners great. Rides hard (not a hard as Steve though!) I saw a thread somewhere else where a guy running the Qualipieces swore by them.
Thanks, I’m going back and digging around some more!
DIwarrior
- Oct 22, 2003
- 2025 SRX LE #473
2025 SW XTX LE
2025 SW LTX GT
2001 SRX
1968 Ski-Doo
- Nope
Looks like there are some options out there.
TPAY243
- Apr 14, 2013
- Northern Wis
- 2020 Yamaha Sidewinder LTX SE
If you are having darting issues there is something funky chicken there, have you checked your ski alignment. What kind of front shocks do you have if they are coil spring take all the preload off of the springs sounds like you have way to much ski pressure. I have 6" Ace bar on the inside and the stock Yamaha 4" round bar on the out side and I can drive mine with one hand and it does not dart at all. You may have to mess with the pre load on the front skid shock also but go a little at a time until you get it were you want it. Make sure your limiter strap is in the stock position also a lot of guys shorten them up not a good idea in my eyes
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
Big groomed trails you say? Tuner 3's you say?
SNOWTRACKERS!
My sled does not dart, does not push even at EXTREME speeds & has THE EASIEST steering including both the new POO & DOO. Their words not mine.
RULES to LIVE BY:
1. Put them on
2. Tune sled to them & your trails
3. Smile
4. PM me & offer me your first born......................................or just thank me
SNOWTRACKERS!
RULES to LIVE BY:
1. Put them on
3. Smile
Mototown
- Sep 11, 2018
- Apex 40 th
Snow trackers, with some centre shock preload ,Mostly hard steering and excessive darting on hardpack trails.
4strokes
- Mar 13, 2018
- charlemont ma
- 18 winder xtx 09 nytro xtx 06 apex gt
I keep my tuners on a hook out in the parts shed. best I have seen them handle yet...
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
Tuners and Snowtrackers !Snow trackers, with some centre shock preload ,
3 years on my Apex , and 3 years on my Sidewinder .
For any ski and skid combination there is a sweet spot .
The art is finding that , to suit your riding style.
DTR 82-27
- Dec 22, 2006
- Drumbo, ON
- 2018 SIDEWINDER S-TX DX 137
SNOWTRACKERS!
RULES to LIVE BY:
1. Put them on
3. Smile
I used Snowtrackers on my RX1 and then two different Apexes over a 12 year period. They worked perfect for me. When I got the Sidewinder, I wasn’t crazy about the Tuners and thought about Snowtrackers. I couldn’t find much info at the time so I went with 6.9 Pilots and 7.5” Shaper bars. This set up is ok but I miss the precise steering of the Snowtrackers. After reading this, I am going to try a set on my Tuners.
Steve, if you want my kids, you can have them. Just let me know where to send them. I have three all in their 20’s. The oldest daughter sleeeps most of the time. The son will be a huge asset to you because he knows absolutely everything already. Don’t worry about the youngest daughter, she will quit whining and pouting once she gets what she wants.
- 17K
