tsiceman
- Jan 31, 2006
- Fishers, In
- Winder ltx le
I have a gs342 in mine, snug fit but works great. I did have to change one wire connector, if I remember correctly.
REDLINE 1
- Sep 20, 2019
- ROUND LAKE IL
- 2018 TCAT
justinator
- Mar 25, 2007
- Maine
- 2023 Arctic Cat Riot 9000
Is this pump mostly a drop in replacement or does some modding need to take place? This is much cheaper than buying a pump through yamaha. thanks for the link90 percent are not genuine. Also there’s two versions of the 255 pump, you want the high pressure version.
https://walbrofuelpumps.com/255lph-walbro-gss342-intank-fuel-pump.html
REDLINE 1
- Sep 20, 2019
- ROUND LAKE IL
- 2018 TCAT
Pretty much . I just changed the stock fuel line over to the new pump and connected the stock pickup. You can plug the stock connectors into the new pump but I wired in the walbro connector plug also bought for amazon when I bought the pump. Been running this setup all season with no problems on a TD Max spool 17 tune.
I have a buddy up in Wisconsin who’s very mechanically challenged and he was able to put the TD pump in LOL
justinator
- Mar 25, 2007
- Maine
Thanks for the info. We all have a mechanically challenged buddy lolPretty much . I just changed the stock fuel line over to the new pump and connected the stock pickup. You can plug the stock connectors into the new pump but I wired in the walbro connector plug also bought for amazon when I bought the pump. Been running this setup all season with no problems on a TD Max spool 17 tune.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
It’s not that hard to change. I will say that if you put in a bigger pump you really should put in a fuel pump relay and separate fuse that can handle more amperage. The stock relay is very small along with the wires.
On my viper the ISC fuse runs the fuel pump, and a host of engine sensors, not sure on the Sidewinder.
There really should be a separate fuel pump fuse anyway.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
I bet super Dave could help with something like this?It’s not that hard to change. I will say that if you put in a bigger pump you really should put in a fuel pump relay and separate fuse that can handle more amperage. The stock relay is very small along with the wires.
Turboflash
- Mar 18, 2019
- Southern MN
Yes, that's the PEFI setup.Cut a hole on the top of the stock plate, install a factory gromet and elbow above the factory surge tank so the fuel returns there rather than the top of the tank. Then plug the return on top of the tank.
I wonder though if the stock pump is getting weak too?
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
PEFI. Assuming your speaking of precision efi?Yes, that's the PEFI setup.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Here’s a picture of the stock relay and the heavy duty one I replaced it with. The stock relay is really only reliable for 13 amps. The replacement is good for 40 amps. The upgraded pump will pull around 15 amps under boost. Your really pushing the limits of the wiring and relay. I located my new relay right next to the pump hat, next to the battery. Short and easy wiring with a 20 amp fuse. Sealed 40 amp relays are very cheap, so it’s not a $$$ issue.
Hurricane recommends just putting in a larger ISC fuse but that’s the lazy mans option which resulted in this fuel pump connection melting. Not cool. I should have known better!
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
They made a good video of the installYes, that's the PEFI setup.
https://www.google.ca/url?sa=t&sour...BMAB6BAgKEAQ&usg=AOvVaw2buZcN9Wbd_qUPaq1ouHEc
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Just rolling home. THANK YOU GUYS! I will dig in this week and see what’s f up.
2004yamahaviper
- Sep 11, 2010
- Ottawa, Ontario
- Spring order 2021 srx
2012 Apex xtx
Anyone running a gss 342 with the stock fuel regulator? Any issues or is the regulator a must?
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
I installed this.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Got a link? And is this plug and play? Sits under the seat by battery I assume.View attachment 163662
I installed this.
