WinterWolf
- Mar 25, 2017
- Connecticut
Well finally got a chance to take sled out on 270 tune with dtay1 empty and and secondary blck/orange wrapped 6-3. On 1200 ft pull getting about 8400 rpm. Is there any thing besides buying qay 70s dalton's that would raise my rpm up dont really want to spend another $200 for cam weight
I believe it was me who told you to buy the QAY 70’s from the start. I remember saying to you that those Dtay weights were gonna be too heavy even empty.
You're gonna have to buy the Qay 70’s.
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
What primary spring and helix u running?Well finally got a chance to take sled out on 270 tune with dtay1 empty and and secondary blck/orange wrapped 6-3. On 1200 ft pull getting about 8400 rpm. Is there any thing besides buying qay 70s dalton's that would raise my rpm up dont really want to spend another $200 for cam weight
Sledbrapping88
- Oct 6, 2019
- Upstate NY
- Yamaha sidewinder ltx
Its stock primary spring and helix
Sledbrapping88
- Oct 6, 2019
- Upstate NY
It was fine until I switch over to xs 825
Sledbrapping88
- Oct 6, 2019
- Upstate NY
If I'm not mistaken the primary is black pink/brown
DMCTurbo
- Nov 12, 2005
Were conditions good? I'm not familiar with your sled, do you have a straight 35 or a 35/39? A primary spring with a higher finish rate would gain you some rpms. You can always grind some weight off the inside tip of your dtya1s.Its stock primary spring and helix
You have a gram scale?Well finally got a chance to take sled out on 270 tune with dtay1 empty and and secondary blck/orange wrapped 6-3. On 1200 ft pull getting about 8400 rpm. Is there any thing besides buying qay 70s dalton's that would raise my rpm up dont really want to spend another $200 for cam weight
Just grind the sides down evenly all the way from top to bottom.
Sledbrapping88
- Oct 6, 2019
- Upstate NY
Weight heavy snow on seasonal road and its straight 35 helix
Sledbrapping88
- Oct 6, 2019
- Upstate NY
Yes how many grams would you take off
WinterWolf
- Mar 25, 2017
- Connecticut
Give that belt some time to break in...I found after about 80-100 miles the belt starts to settle in and gets better. Give it some more time and see if R’s increase.
2-3Yes how many grams would you take off
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
You really need a surface grinder to do that. You can also just grind the backside of the weight. I like to run a pin through all three weights, even them up and clamp in a vice and grind with a coarse flap wheel.
Fine tune each with your scale and done.
That would be best. But I've done many. I just take my time and do it carefully.You really need a surface grinder to do that. You can also just grind the backside of the weight. I like to run a pin through all three weights, even them up and clamp in a vice and grind with a coarse flap wheel.
- 56K
