![](/styles/TYLifeMember.gif)
![](/styles/vip.gif)
I think it’s a assembly issue from factory. They set them to the tight side of tolerance and sometimes error a bit.
jeff_yam
I'm on the way to adjust my valve and i'm wondering if its possible to verify the new valve clearance without installing the chain tensionner?
No. Reason why is you should always do the final check after turning motor over by hand a few times. The clearance will change after this since oil is caught between shim and bucket that would not normally be there. I think its a valid habit I have always done on shim type adjustment. Also keep tension with a finger on chain between the gears. Dont want it to jump time with valvecover off. Valvecover adds tension.I'm on the way to adjust my valve and i'm wondering if its possible to verify the new valve clearance without installing the chain tensionner?
jeff_yam
Ok then I have to compress and reinstall the chain tensioner, then gently turn the engine a few turns with a little tension on the chain between the gears before proceeding to final check of the valve clearance?
Also where the oil drain hole are located? Just to be extra carefull to not drop a shim in it...
Froggy
- Apr 29, 2016
- Kipawa,Quebec
- 2020 Winder LTX SE 16600 km and counting
2016 Viper LTX LE 23986 km sold
2015 Viper LTX DX Wife's 22500 km sold
2010 Vector LTX GT 25000 km sold
2024 SRX Leftover 0 km
Yes did mine 2 years ago and went to do a second adjustment on 2 valves and dropped a shim down the oil hole. Almost cried. Removed the cylinder head and found the shim stuck to the head gasket.Ok then I have to compress and reinstall the chain tensioner, then gently turn the engine a few turns with a little tension on the chain between the gears before proceeding to final check of the valve clearance?
Phazer2Viper
- Apr 14, 2014
- Slinger, WI/ Three Lakes, WI
- 2015 Viper LTX-DX 15,000 miles and counting!
2008 Phazer GT 128" track 10,444 miles (sold)
2008 Nytro RTX 136" 3800 miles (sold)
2000 Phazer 6500 Miles (Sold)
1990 Phazer II 10,000 miles (sold)
Well add another one to the list. I just had mine checked at the local dealer. 5 of 6 were too tight and 2 had 0 clearance. Hopefully i wont have to have this done for the “recommended” 25k miles. Only had 10k on mine right now.
Cyl 3 valve 1 still in spec?
Phazer2Viper
- Apr 14, 2014
Not sure. Ill have to ask when i pick it up.
jeff_yam
For mine, yesCyl 3 valve 1 still in spec?
jeff_yam
Did the chain tensionner will release only when the engine will start for the first time? or we can get it release by cranking without spark plugs?
That’s 4 I know of. Factory did something wrong. That valve also had the smallest shim including mine.For mine, yes
Phazer2Viper
- Apr 14, 2014
So u think the factory messed something up so we shouldnt have that problem now? Or is this going to be a recurring thing every 6-10k?That’s 4 I know of. Factory did something wrong. That valve also had the smallest shim including mine.
Tight intake valves makes for hard starting! This is what I find on my bikes.
Yea these are exhaust valves going tight though.Tight intake valves makes for hard starting! This is what I find on my bikes.
pdiddy
- Oct 12, 2004
- Southern Maine
- '11 Apex; '16 Apex XTX; '18 Indy 600 SP;
X2! - Just read the entire thread. This is the elephant in the room.agree also, still wondering if its the front exhaust running hotter. nytros lasted forever compared to vipers as far as lash goes
