Allan
Good job. did you tip the engine or hold the cam chain up tight to keep pressure on tensioner?Well I just put final bolt in after Spring project of a valve adjustment. All the intakes were fine, and all exhaust valves needed attention. Two of which I couldn't even measure, smallest feeler gauge was .002". So I ordered all exhaust shims from Yamaha ($9 each) I guess -.010" for the tight valves and I guessed correctly. I bought a few extra shims that were -.012" from what was in there. Well cranked sled over with switch off to get oil pressure to tensioner. Then hit kill switch and started like a charm. No leaks or missing bolts. Still not sure if this will fix my cold start issue, since its 60 degrees here. O 'well i'll wait until October. At least I can eliminate that valves need adjusting. All valves are perfect now. Big thanks to cannondale27 for advice. No special tools needed except Service Manual. Not sure time it took, worked on it few hours here and there after dinner. Anyone need advise on doing this job, hit me up. (did it with motor in sled)
sxr70001
- Dec 4, 2010
- Michigan
- Sidewinder LTX SE
SR Viper RTX SE
Good explanation at 39 minutes about valve clearances. This is essentially the same motor as the 998 I believe. They are also playing with cam timing which I think is pretty cool.
MarkAttack
I adjusted the vales on my Yamaha YZ-400-F dirt bike .. it also is a 5 valve head.. You have to buy a bunch of shims from the Yamaha Dealer.. The WR-400 did not have as much power and top end as the YZ did .. YZ = Motocross WR= Enduro Trail bike . The Dealer told my friend who had a WR-400 that the only differance was the cam timing .. So he advanced the cams 1 tooth and it has the same Top end as a YZ
The WR has minimal lights wide ration transmissions and much softer springs in the Suspension ..
Barry
I tipped engine forwardGood job. did you tip the engine or hold the cam chain up tight to keep pressure on tensioner?
Snorunner
- Jul 17, 2018
- Deerwood
- 2016 Vector XTX
2017 Vector XTX
2001 Arctic Cat
Diagnose tight valves? I will date myself. A compression test when cold will show low compression if exhaust valves are held open when cold. So would a cold cylinder leakdown test. Another old school test on exhaust valves. If you have a burnt exhaust valve. Or one that's open when it should not be is to hold a piece of card stock. Firm paper against the exhaust pipe.While engine is running. When a piston goes down on the intake stroke if the exhaust valve is is leaking it will pull the card stock against the pipe. On the intake stroke. If you have dual exhaust V8 or V6 you could even tell what side of the engine the valve is leaking on. Otherwise it always blows away from the pipe. Because when the piston is going down it is pulling Vacuum. If the valves are closed or sealed properly. It will just not suck towards the pipe. Just food for thought. I am very interested in this subject. Because in the last 3 years I have bought my first new sleds. Bought a 16 & 17 Vector. And wanting to know what to expect. When they get older.
Mike P
- Nov 18, 2015
- Berlin CT
- Sr Viper R-TX SE
- Berlin CT
Nothing wrong with an "old school" approach. Wish we had more of that "old school" thought process while trouble shooting on TY. Some times the simple and some what low tech methods work as well or better than others.Diagnose tight valves? I will date myself. A compression test when cold will show low compression if exhaust valves are held open when cold. So would a cold cylinder leakdown test. Another old school test on exhaust valves. If you have a burnt exhaust valve. Or one that's open when it should not be is to hold a piece of card stock. Firm paper against the exhaust pipe.While engine is running. When a piston goes down on the intake stroke if the exhaust valve is is leaking it will pull the card stock against the pipe. On the intake stroke. If you have dual exhaust V8 or V6 you could even tell what side of the engine the valve is leaking on. Otherwise it always blows away from the pipe. Because when the piston is going down it is pulling Vacuum. If the valves are closed or sealed properly. It will just not suck towards the pipe. Just food for thought. I am very interested in this subject. Because in the last 3 years I have bought my first new sleds. Bought a 16 & 17 Vector. And wanting to know what to expect. When they get older.
Thank you.
Vmax
- Mar 20, 2018
- Lasalle
- 2014 Arctic Cat ZR 6000 El Tigre
I will admit that I did not read through the entire thread but I do recall reading something about valve adjustment being under warranty up to several thousand miles. Is this true and if so what is the max miles to get the warranty valve adjustment done.
I have a 2015 El Tigre 7000 with 7500 miles
I would say you would have to be under warranty and be having issues. Miles dont matter as far as warranty.I will admit that I did not read through the entire thread but I do recall reading something about valve adjustment being under warranty up to several thousand miles. Is this true and if so what is the max miles to get the warranty valve adjustment done.
Allan
I had warranty and 18000km on machine when I needed valves adjusted . Yamaha said valve adjustment is maintenance . But in the book valve adjustment is not needed tell 40,000km. Yamaha said i was not covered. This went back a forth for a week. Then i found a person on this site that had 1/2 cost covered under warranty. He sent me his bill, i sent it to Yamaha and then they did the same for me. But I was fighting with them for several day and posting in several places, this all got there attention and they came threw.
4strokes
- Mar 13, 2018
- charlemont ma
- 18 winder xtx 09 nytro xtx 06 apex gt
remember what they did for yellowknife? they installed a primer and had a procedure to start it involving a generator/charger and heat blanket etc. and they still didn't look at the valves
DTJ
- Mar 31, 2016
- Brainerd, MN
- 2014 Yamaha Viper XTX, hurricane 190 kit
2013 Yamaha Apex XTX
2017 Yamaha Sidewinder BTX
Yamaha fully warrantied my valve adjustment at around 6000 miles I think in the 4th year of extended warranty. I wonder how much influence or difference the dealer makes when turning in warranty work.
4strokes
- Mar 13, 2018
- charlemont ma
so was there a running issue?Yamaha fully warrantied my valve adjustment at around 6000 miles I think in the 4th year of extended warranty. I wonder how much influence or difference the dealer makes when turning in warranty work.
DTJ
- Mar 31, 2016
- Brainerd, MN
Yes, it wouldn't start cold without throttle and eventually it got to the point I had to hold the throttle just to get it warmed up. Once warmed up, it was fine. All of my exhaust valves were tight. I've put about 3000 miles on since the valve adjustment without any issues.
Vmax
- Mar 20, 2018
- Lasalle
That's what I figured, thanks for the replyI would say you would have to be under warranty and be having issues. Miles dont matter as far as warranty.
Allan
Yamaha is all over the place with this. I think dealer has a lot to do with getting covered. Because Yamaha only gives them about 4 hours to do it and it takes around 8. so a dealer is out $.Yamaha fully warrantied my valve adjustment at around 6000 miles I think in the 4th year of extended warranty. I wonder how much influence or difference the dealer makes when turning in warranty work.
