When I had it off I went from top removing header. Gasket can be reused.Hose should be here tomorrow. Did u change yours from top removing headers or did u go through bottom like im planning. Not sure if its gonna work.
Not sure. It's a feel kind of thing. Tight but not so tight you wreak the clamp. Should for sure see the hose squish.Got it on from underside. Removing bolt in solid piece did help
I install 2 new clamps same type as was on heat excganger side. Screw type.
Whats the torque spec on those and or how tight
