TPAY243
- Apr 14, 2013
- Northern Wis
- 2020 Yamaha Sidewinder LTX SE
Ya I know it really doesn't tell ya one way or another but then after you check out and pay them it will say there on back order. Don't feel bad it is not just the snowmachine division I waited 2 months this summer for a part for my YXZ.
Beauryan Best
- Feb 16, 2021
- Nome, AK
- 2014 SR Viper
Did a new speedsensor get it started?
I assume the new stubshaft got him runningDid a new speedsensor get it started?
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
Revisiting this stubshaft/gear slipping that some seem to have.
Can that gear be removed and pressed back into the correct positon?
Yes, and I recommend loctite or a little weld.Revisiting this stubshaft/gear slipping that some seem to have.
I had a hard starter here last year and the signal ring wasn't aligned and the exhaust valves were tight as well. Intakes were good.
Started good after.
I have two more just arrived that are hard starters also. Have yet to get at them, but will post what I find.
Started good after.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
Coming back to this as I have one coming in for an erratic start.
Are you guys fixing the existing assembly or getting new? It seems like if it moved it could be moved back and secured.
They can be moved. You can use loctite, or I've seen a small spot of weld on some.Coming back to this as I have one coming in for an erratic start.
